Gtir Motorsport club » General Discusion » Random banter » Citroen dispatch 1.6 hdi 60 plate
1 Citroen dispatch 1.6 hdi 60 plate on 4th April 2015, 8:50 pm
Ok so massive shudder under load thought dual mass turns out it's solid parted box off today as several checks by others on all sorts from tyres to bushes etc all ok. Soon as you dip clutch shudder goes even when vehicle is moving so it's clutch box related. Gears all work fine. It dose it in every gear no wines nor crunches just massive shudder Any ideas ? Diff bearings ?
It sounds rattley when shaft is spun on box but so did a lot of gear boxes pug and shitron I looked at today
2 Re: Citroen dispatch 1.6 hdi 60 plate on 4th April 2015, 9:16 pm
I might be thinking of other car but is citroens/pug inner cv joints  spring loaded?? and did car had by any chance cv gaiter or something done to it which would require removing joint hub etc?? what i've seen couple of times is that spring in inner cv joint going adrift locking inner cv joint an made it feel like engine and box was trying push to one side.... i hope this makes sense lol
3 Re: Citroen dispatch 1.6 hdi 60 plate on 5th April 2015, 8:14 am
Its a van not sure. Would it still not do this without excelerating ie it say you get up to 50mph its doing it soon as you dip clutch it goes
4 Re: Citroen dispatch 1.6 hdi 60 plate on 5th April 2015, 9:02 am
Does it drive ok? i.e get up to speed as normal. I ask as wonder when it could be a badly worn spline on a driveshaft going into a hub?
5 Re: Citroen dispatch 1.6 hdi 60 plate on 5th April 2015, 10:08 am
@johnny gtir wrote:Its a van not sure. Would it still not do this without excelerating ie it say you get up to 50mph its doing it soon as you dip clutch it goes
Well it would do it all the time and it would be worst when turning...
6 Re: Citroen dispatch 1.6 hdi 60 plate on 5th April 2015, 7:01 pm
Drive shafts are fine and you would think it would get worse when turning if diff but it dose not. I am stuck
