Gtir Motorsport club » Tech room » Help and Advice » Misfire
Misfire
26 Re: Misfire on 14th April 2015, 6:36 am
Thermal
Good luck with the head tighten, it dosent sound as if you have been running it too long with the loose studs, so fingers crossed.
I did not know ARP were so useless.
27 Re: Misfire on 14th April 2015, 9:21 pm
scotty6860
Update all the new head bolts are in and some of the arp bolts had worked up which I found quite shocking should of took a pic of the worse one and sent it to arp so they know what they are selling out in the morning for the compression test
28 Re: Misfire on 15th April 2015, 4:16 pm
scotty6860
GQuick update did not get away with it got all the compression back but under boost its pressure up the Water system so head gasket is gone so just orderd a cosworth head gasket new oil pump new warter pump and timing chain while its apart might as well get them changed
But due to waiting for parts I am going to miss the rr day at bobs
29 Re: Misfire on 15th April 2015, 5:24 pm
Sorry to hear that scotty some bad luck is that .... sounds like your on it though Wink
30 Re: Misfire on 15th April 2015, 5:39 pm
scotty6860
J
cant fix it It's just one of those things mate we will own these cars but in 12 years  of onwership this is the biggest job I have had to do on her
31 Re: Misfire on 15th April 2015, 7:39 pm
was a gamble scott and well worth the try as you may have struck lucky.
im now wondering whether swapping to a 1.3 bar pressure cap has actually blown the hg
the increased pressure in the system coupled with the lifted arp studs could just have put the final nail in the coffin.
pity you wont have her done for Saturday though, is 2 days not enough to get it done?, ive even got a hg down here (new one) you can borrow until the other arrives if that helps at all
32 Re: Misfire on 15th April 2015, 9:42 pm
scotty6860
Yer was definitely worth the try and think you are very right about the 1.3 bar cap
Head gasket comes in the morning but got to wait 3 days for oil pump and water pump so will strip it all down and get the head of for testing just to be safe but on a good note at least I am finding out about my engine and tackling the jobs my self
33 Re: Misfire on 15th April 2015, 10:32 pm
What's wrong with the oil pump then? Not something you would normally change unless you had a bottom end problem
34 Re: Misfire on 15th April 2015, 10:46 pm
scotty6860
Why it's apart just going to change the lot
35 Re: Misfire on 15th April 2015, 10:48 pm
You'll need to drop the sump aswell to do the oil pump
36 Re: Misfire on 15th April 2015, 10:50 pm
scotty6860
Is it just the sump bob or is it more evolved than that
37 Re: Misfire on 15th April 2015, 11:01 pm
yep just sump, pulleys front engine mount and allie bracket think that's about it scott
38 Re: Misfire on 16th April 2015, 6:54 am
Thermal
Scotty6860, I will be going to Bobs on Saturday, meeting up with RobIOW on the way, if there is anything you need from Bobs I could bring it back for you, if you still fancy going up if you are not elbow deep in Pulsar, I could pick you up and drop you off, if you are anywhere near Brighton/M23, I will be going up about 9:30, returning around 4:00ish after a natter and a burger.
39 Re: Misfire on 11th May 2015, 9:19 pm
scotty6860
Well the head is off and the head gasket is gone where the arp head bolt undone its self good new is head and block are fine just got to put it back together now more blood cant fix it
40 Re: Misfire on 11th May 2015, 9:58 pm
Best thing you can do with those arp studs is use then as drifts :-)
I don't use any higher pressure caps than 1.1bar, 1.3bar just not needed really & on old cooling systems they a pain in the ass ...
41 Re: Misfire on 24th May 2015, 7:51 pm
scotty6860
Quick update car is back together in the morning new oil and coolant and going back to a 1.1 bar cap fingers crossed got the timing all right been turned over by hand with no problems then just got to sort my new brembos out by a bit of shiming then book in at bobs for rr
42 Re: Misfire on 25th May 2015, 7:31 pm
scotty6860
Car is up and running only fault I have is its not charging it self
43 Re: Misfire on 25th May 2015, 9:54 pm
Have you tested the alternater ...???
44 Re: Misfire on 25th May 2015, 9:57 pm
scotty6860
Going to test it tomorrow can't find my meter and the battery is on charge as it was dead and still on charge would it be possible that it was the battery
45 Re: Misfire on 25th May 2015, 10:08 pm
It could be the battery although without testing it its really hard to tell you can test from the battery once its running you ideally looking at figures around 14 ....
46 Re: Misfire on 25th May 2015, 10:20 pm
scotty6860
Ok cheers mate will get that sorted
47 Re: Misfire on 26th May 2015, 5:46 pm
scotty6860
Right is the alternator so one coming of bob done new compression test to day getting 165 on all four so looking good quick drive when alt is fitted then up to bob for rr
48 Re: Misfire on 26th May 2015, 6:31 pm
Good news on the comp test .... shame about the alternater but it could be a whole of worse things to have to change ....
