Gtir Motorsport club » Tech room » Help and Advice » Stem seals
Stem seals
1 Stem seals on 26th April 2015, 10:04 pm
Hi all just to make sure are all sr20det stem seals the same??
2 Re: Stem seals on 26th April 2015, 10:38 pm
Don't believe they are, our inlet seals are smaller in diameter to the exhaust side
3 Re: Stem seals on 26th April 2015, 10:56 pm
But will eg 200sx seals fit to gtir??
4 Re: Stem seals on 27th April 2015, 8:28 am
SR DE & DET will fit inlet, most SR with sodium filled exhaust valves are same size from what I seen.
I always buy Nissan OEM as basically fit better (perfect) & never get any hassle.
5 Re: Stem seals on 27th April 2015, 7:57 pm
I was looking at supertech stem seals but I might give nissan a ring first problem is that they are useless and always crying when asked to check something for a import...
Anyway thanks a lot Smile
6 Re: Stem seals on 27th April 2015, 8:26 pm
I always belived nissan fitment were best
7 Re: Stem seals on 27th April 2015, 8:36 pm
Give your Nissan man a slap in the face from me.
Just give them A UK sunny GTiR reg number
I will add part numbers for them when got time spare.
8 Re: Stem seals on 27th April 2015, 8:55 pm
I was actually thinking to nick gtr from their display and drive it in to parts department bounce015
I think I've got website somewhere with nissan parts no
http://nissan4u.com/parts/sunny/er_n14/1992_2/type_23/
9 Re: Stem seals on 27th April 2015, 9:10 pm
http://nissan4u.com/parts/sunny/er_n14/1992_2/type_23/engine_mechanical/cylinder_head_rocker_cover_camshaft_and_valve_mechanism/illustration_2/
http://nissan4u.com/parts/info/13207D0111/
http://nissan4u.com/parts/info/13207D4201/
Good idea with the gtr :-D
10 Re: Stem seals on 27th April 2015, 9:15 pm
Awesome thanks Mr B i owe you some green tea again
11 Re: Stem seals on 27th April 2015, 9:24 pm
Okay that 2 green tea's you owe me :-)
Take those details on your phone or print it out, is couple alternative numbers if look at first link.
ICP do cometic viton seal kit for £20 but not sure I would trust it.
http://www.importcarparts.co.uk/parts-info?id=10575&cat=87&sub=119&sec=1184&var=0&dc=&gen=&searchKey=&searchPart=
12 Re: Stem seals on 27th April 2015, 9:29 pm
well I've heard that cometic stuff is not that great and was looking at supertech which apparenly makes good stuff
http://www.steelconrods.co.uk/product_info.php?cPath=22_39_169&products_id=454
I'll see if nissan can help and I'll go from there
13 Re: Stem seals on 27th April 2015, 9:46 pm
Yeh I go nissan OEM on these unless have supply issue, had issue with pattern valve seals before.
14 Re: Stem seals on 27th April 2015, 11:51 pm
^^^ likewise
It's a job you don't want to have to do again so better off getting them from nissan
15 Re: Stem seals on 28th April 2015, 6:26 pm
Yeah I've done it once without taking head off it was lovely experience....
16 Re: Stem seals on 28th April 2015, 7:33 pm
Did you do it with packing the bores mate ????
17 Re: Stem seals on 28th April 2015, 7:41 pm
Yes I've just put loads of garden yarn or whatever you call it just wanted something nice and soft and squeezable oh fook that just sounds wrong lol! but yeah string compress it and funny looking spring compressor it went ok except last one when collet dropped inside cylinder
18 Re: Stem seals on 28th April 2015, 8:22 pm
Yes they one of those items you don't want be revisiting when engine built up .
I've had after market that been poor looking fit so didn't use them & had issue with ones leaking within few months so stick to OEM when can. Have used cometic ones before but not on an R & was fine but I would want test on an R for a year before I would start recommending personally
Supertech seems 50/50 on opinion, a lot of mitsi builders had complaints.
Do think some issue is fitment on that though as have 2 types of seal pending on valve springs used, also if you got wear issues with valve stem & guide, seals won't work well. Nissan OEM seals are not a huge amount more if supplier friendly & if available it reduces potential issues on rebuild work.
I use Nissan cranks seals, rocker seals etc as far better & don't end up revisiting the job .
19 Re: Stem seals on 28th April 2015, 9:05 pm
@Gostek wrote:just wanted something nice and soft and squeezable
cum
It sorted my seals out...
20 Re: Stem seals on 28th April 2015, 9:07 pm
^looks like your shaft leaking though :-S
21 Re: Stem seals on 28th April 2015, 9:09 pm
@shroom wrote:
cum
Damn right it did!!! bounce015
