Gtir Motorsport club » Tool section » JB Weld
JB Weld
1 JB Weld on 7th May 2015, 9:56 pm
Anyone used JB weld products before? I have heard great these about these products. I wanted to seal up a couple of vacuum ports on my intake manifold. I could take the manifold off and get someone to weld it but JB weld was another option suggested to me.
http://www.jbweld.com/collections/automotive/products/j-b-weld-twin-tube
2 Re: JB Weld on 7th May 2015, 10:21 pm
What about the low heat weld sticks someone put on here a while back ?
3 Re: JB Weld on 7th May 2015, 10:25 pm
Arghhh yeah that wouldn't be a bad idea, I'd need to buy a torch aswell for the job though.
4 Re: JB Weld on 7th May 2015, 10:26 pm
Also never overlook araldite imo it's better and stronger
5 Re: JB Weld on 7th May 2015, 10:44 pm
Them ali sticks ... looks quite good .... araldite is a good product and has been going for years .... although i would think you would need to glue a cap on or something
6 Re: JB Weld on 7th May 2015, 10:53 pm
Cheers guys, I'll check out araldite aswell. I was going to pull the vacuum barb out and seal up the hole that's left. So what ever option will work out easy.
7 Re: JB Weld on 8th May 2015, 3:34 pm
I used job weld about 10 years ago and to be fair it was really good stuff
8 Re: JB Weld on 8th May 2015, 8:34 pm
Gtirchris
Yep jb weld is good stuff , I sealed up a cracking in an engine block with it about 5 years ago and its still ok and hasn't leaked Smile
9 Re: JB Weld on 9th May 2015, 12:12 am
This stuff will be able to hold 25psi roughly shouldn't it?
10 Re: JB Weld on 9th May 2015, 8:12 am
Thermal
At work we use JB weld on intake manifolds running +1.5bar, seems pretty good.
11 Re: JB Weld on 9th May 2015, 9:00 am
Sweet, I'll just give it a go, no harm done if it doesn't Smile
12 Re: JB Weld on 17th May 2015, 3:13 am
colin22
I used jb weld to plug up holes in the oil pump loll. Works good.
13 Re: JB Weld on 17th May 2015, 8:23 am
Good stuff Colin, first post, welcome to the forum Smile you should post in the intro section if you like Smile
14 Re: JB Weld on 1st June 2015, 9:03 pm
Picked some jb yesterday, went to use it and half the tube was solid fuming back to the auto shop.
15 Re: JB Weld on 4th June 2015, 1:47 am
Also look at Selley's Knead-It, another decent product and available almost anywhere in Australia.
16 Re: JB Weld on 4th June 2015, 8:47 pm
Never heard of it ... is it only an australian product ....
17 Re: JB Weld on 4th June 2015, 8:50 pm
Within the next month we are believe it or not producing our own stuff and putting it to market as a branded product
It knocks job weld in to touch
We will be giving away 5 free tubes for people to try
It's that good there will be no need to helicon like a bolt any more
Will tell all when it goes to market
18 Re: JB Weld on 4th June 2015, 9:28 pm
Sounds intresting ... so is it like a chemical metal type then bob ???
19 Re: JB Weld on 4th June 2015, 10:06 pm
Sounds good, would be keen to check it out Smile
20 Re: JB Weld on 5th June 2015, 10:34 am
impressive stuff !!!! kept that a bit hush hush didnt you Laughing best of luck with it
21 Re: JB Weld on 5th June 2015, 10:37 am
not saying anything yet guys for obvious reasons but its something we partially made / found by accident a few months back
lets just say that for example you got a boogered thread in a cylinder head and the new stud is slopping about in the hole........ well fill the hole with our magic compound and insert the stud leave it for half hour or so then you can torque it up to 60nm and it will not move (almost to the point of snapping the stud) were still testing the product with heat and other vigorous tests to test the tensile strength
liquid steel, Jb weld, araldite, chemical metal infact no other product I know of will do that, they will all start to move after around 15-20nm
Im really excited about getting this product to market once the branding and packaging is finished we will approach leading motor factors to stock the product on the shelves as its that good and its uses in the automotive industry are potentially huge.
22 Re: JB Weld on 5th June 2015, 11:35 am
Sounds awsome Bob I have a good few things that it could be tested on lol
23 Re: JB Weld on 5th June 2015, 11:38 am
It does sounds very promising, I was thinking the same thing, I have a few things I'd love to try it on Smile
24 Re: JB Weld on 6th June 2015, 2:16 am
As said guys yeah gotta keep it quiet until patents in place to protect my product. But will be giving around 10 - 20 boxes away to people on this forum for you to try, it'll retail for around £16-18 and be a high end product in that particular field as there simply is nothing on the market to rival what this stuff can do
You'll be amazed I can assure you of that and I see a new Nismo GTR on the horizon if all goes accordingly  Cool
I strongly believe it will be huge in the automotive industry and make me and Clare a fair few quid hopefully but don't worry I won't forget you guys lol, and il still be fixing pulsars and doing the Motorsport stuff we're doing but will be on an even bigger scale to hopefully rival the likes of Svm and litchfield, that's my goal anyway and won't stop till we get there!
25 Re: JB Weld on 6th June 2015, 5:52 am
Bob I was going to say think of its heat potential and from my background the electrical conductivity it takes very little to make it conduct or resist which if you could get it in both forms really opens the market up way above and beyond the automotive market.
Remember the above statement when you make your millions
There are a few people women inc mouths I would like to shut this could be the answer lol
