Gtir Motorsport club » General Discusion » Gtir related Discussion » Apexi power fc
Apexi power fc
1Apexi power fc Empty Apexi power fc on 22nd May 2015, 11:16 am
Does power fc have any built in antilag or launch control features ? Just wanna go bang bang pop pop haha ! I've got rocker arm stoppers fitted so that will stop me throwing a rocker arm and a nice big strong turbo! Any help will be appreciated Smile
2Apexi power fc Empty Re: Apexi power fc on 22nd May 2015, 11:32 am
Think its just the power fc pro that has those features.
3Apexi power fc Empty Re: Apexi power fc on 22nd May 2015, 11:34 am
Aww damn Sad lol might have to buy a bee-r
4Apexi power fc Empty Re: Apexi power fc on 22nd May 2015, 11:34 am
Power fc pro has launch control. .
Basically a 0mph rev limiter .
5Apexi power fc Empty Re: Apexi power fc on 22nd May 2015, 11:46 am
I thought they did have launch control but never als .... not unless its like the drag pro version ...
6Apexi power fc Empty Re: Apexi power fc on 22nd May 2015, 12:10 pm
I wouldn't bother, bee-r is a awful piece of 5hit.
If you get your car mapped well it should be quite bang bang pop pop without need for anything else.
7Apexi power fc Empty Re: Apexi power fc on 22nd May 2015, 7:04 pm
I got the fc pro I know it has launch controll was always told it supports some form of Anti lag
8Apexi power fc Empty Re: Apexi power fc on 22nd May 2015, 7:11 pm
Pro version cuts ignition high rpm instead of fuel which could cause knock at high power. Pro version also has a second static Rev limiter which alows constant rpm hold which allows for launches  or similar to that I have wrote. So I read
9Apexi power fc Empty Re: Apexi power fc on 23rd May 2015, 2:39 am
You want a gems stand alone ecu Pete Smile
10Apexi power fc Empty Re: Apexi power fc on 23rd May 2015, 4:00 am
Going stand alone will give you so many other options other than launch control etc aswell
11Apexi power fc Empty Re: Apexi power fc on 23rd May 2015, 5:51 am
Features which a lot of people will never use on a pulsar. Unless your running other than out the norm ie bigger injectors z32 maf and bigger turbo. Woody we had a rolling road day and had R's with stand alone and set up by mappers. Guess what produced the best power for its set up and best afr readings etc. Spikes which was set up using his in car wideband gauge. Manual boost controller (Dawes device) and a old twisty dial air/fuel controller
12Apexi power fc Empty Re: Apexi power fc on 23rd May 2015, 6:52 am
That's a very point johnny and I do agree with you. I've always stood by only upgrades that are absolutely required if you have the supporting mods. Power fc are proven time and time again to great ecus. It just depends what you are planning to do with the car in the future, stand alone's provide more flexible in the future Smile
13Apexi power fc Empty Re: Apexi power fc on 23rd May 2015, 6:53 am
Very valid point though thumbsup
14Apexi power fc Empty Re: Apexi power fc on 23rd May 2015, 7:49 am
Thanks for all the info guys !!! I'm more than likely gonna get a motec or a gems Ecu next year but the power fc will more than meet my needs for now Smile
15Apexi power fc Empty Re: Apexi power fc on 23rd May 2015, 9:24 am
Kate&tim
Kate&tim
is this the kind of thing ?
https://youtu.be/or6-OTK90vk
16Apexi power fc Empty Re: Apexi power fc on 23rd May 2015, 9:31 am
@johnny gtir wrote: Spikes which was set up using his in car wideband gauge. Manual boost controller (Dawes device) and a old twisty dial air/fuel controller
Very true, although not everyone has days and days to twist knobs Laughing
17Apexi power fc Empty Re: Apexi power fc on 23rd May 2015, 9:50 am
No not quite kate and Tim I was thinking something more like this
https://m.youtube.com/watch?v=Bchc8TS95Qc
18Apexi power fc Empty Re: Apexi power fc on 23rd May 2015, 5:50 pm
Spark plug spike
Spark plug spike
Haha Tom, didn't have to do it for days and days just a couple of runs then adjust then test again until the AFRs and timing were within the safe zones.
As Johnny said I'm happy with the results of the old fashioned controller so I will put off upgrading to anything electronic until I get the correct supporting mods.
Apexi power fc <a href=Apexi power fc Image_27" />
This is the run from the RR day at Bobs set at 1.1 bar boost with standard turbo, ECU and injectors
Apexi power fc <a href=Apexi power fc Image_21" />
19Apexi power fc Empty Re: Apexi power fc on 23rd May 2015, 7:44 pm
Power ain't everything and I don't claim to be a expert but my eyes show a great curve. Well done sir spike
20Apexi power fc Empty Re: Apexi power fc on 23rd May 2015, 11:17 pm
That's really cool, the old technology is still making good results Smile
21Apexi power fc Empty Re: Apexi power fc on 23rd May 2015, 11:34 pm
It's a case of what you need future profing without over complicating what you need for your set up.
22Apexi power fc Empty Re: Apexi power fc on 30th May 2016, 7:11 am
kevmc76
kevmc76
Has any one re-set the apexi back to base map before and how do you do it?
23Apexi power fc Empty Re: Apexi power fc on 30th May 2016, 7:37 am
Not sure if you can do it via hand controller if not you need the softwear to do it fc data logit. Where you based ?
24Apexi power fc Empty Re: Apexi power fc on 30th May 2016, 7:44 am
kevmc76
kevmc76
Am up in Scotland near Dundee,
