Gtir Motorsport club » Tech room » Help and Advice » external wastegate and bleed valve
1 external wastegate and bleed valve on 23rd May 2015, 7:50 pm
Is this plumbed in correct?
I cant get more than .8bar of boost Sad
I have wound the bleed valve right out and it still sits at .8bar.
I have removed the bleed valve and plumbed the vacuum into bottom of the wastegate and vented the top off and still only .8bar Sad
I was told it's a 1.4bar wastegate.
2 Re: external wastegate and bleed valve on 23rd May 2015, 8:03 pm
What turbo is it stu ? Actuator ?
3 Re: external wastegate and bleed valve on 23rd May 2015, 8:06 pm
Gt2871r turbo and was told it's a forge external actuator mate.
4 Re: external wastegate and bleed valve on 23rd May 2015, 8:10 pm
Don't take this as right stu should it not come off turbo into a tee into bottom into bleed valve out bleed valve into the side and pipe off top to plenum or am I getting mixed up
5 Re: external wastegate and bleed valve on 23rd May 2015, 8:13 pm
I have no idea mate lol the standard one does tho dosnt it?
I'm shit with the vacuum mate lol
This comes from the plenum to the external wastegate.
6 Re: external wastegate and bleed valve on 23rd May 2015, 8:14 pm
Also my screamer doesn't scream Sad
7 Re: external wastegate and bleed valve on 23rd May 2015, 9:30 pm
Is this nut done up to much?
8 Re: external wastegate and bleed valve on 23rd May 2015, 11:23 pm
Not sure about the boost problem stu but from my understanding it's plumbed correctly
9 Re: external wastegate and bleed valve on 24th May 2015, 9:54 am
gtir_pimp
Is that an actual bleed valve or is it a Dawes type device with ball and spring inside? The Dawes type devices with ball and spring work by winding them in for more boost, have you tried that?
10 Re: external wastegate and bleed valve on 24th May 2015, 10:13 am
Thanks for replies. Yes it has ball and spring.
I will try winding it in fully then.
Has anyone else had to take the feed from the plenum? My turbo doesn't have a nipple..
11 Re: external wastegate and bleed valve on 24th May 2015, 11:05 am
I've had the feed from the plenum before without any problems. My turbo didn't have a port earlier so I drilled the intercooler pipe right before the turbo and put a fitting in
12 Re: external wastegate and bleed valve on 24th May 2015, 12:06 pm
@gtir_woody wrote:I've had the feed from the plenum before without any problems. My turbo didn't have a port earlier so I drilled the intercooler pipe right before the turbo and put a fitting in
I was thinking of doing it this way.
Did you have better results like this Woody?
13 Re: external wastegate and bleed valve on 24th May 2015, 8:42 pm
To be honest stu only had a run in tune with the feed in the intercooler pipe but there wasn't problems reported.
