Gtir Motorsport club » Tech room » Help and Advice » piping
piping
1 piping on 24th May 2015, 12:03 pm
TomeiR
driving in third on boost the boom. car started brick walling. and heard a pop. black smoke. thought shit there goes turbo.car lost power and idle was trying to die. just about got home. flipped the lid to find intercooler pipe had come off. put it back in place. engine starts up. no black smoke. but isle still wants to die. thinks its thrown up a fault again.
went into limp mode.
2 Re: piping on 24th May 2015, 12:07 pm
Clear the codes and try again.
3 Re: piping on 24th May 2015, 12:16 pm
TomeiR
can you direct me to the walk through of clearing codes
4 Re: piping on 24th May 2015, 12:16 pm
TomeiR
found it lol
5 Re: piping on 24th May 2015, 1:21 pm
When myne did this tomei r my fourth spark plug had popped up too and only when I put it back in place did it idle right ! Hope this helps
6 Re: piping on 24th May 2015, 3:00 pm
How long did it run with pipe off ?
7 Re: piping on 24th May 2015, 3:10 pm
TomeiR
it ran for maybe 2-3 minutes with it off
where do u think the black smoke came from
8 Re: piping on 24th May 2015, 3:13 pm
TomeiR
also ill check the sparks when i get back
9 Re: piping on 24th May 2015, 3:20 pm
Black smoke is car massively over fuelling which they do if a boost pipe pops off
10 Re: piping on 24th May 2015, 3:26 pm
Not quite sure why, but mine did exact same thing and changing the spark plugs fixed it...
11 Re: piping on 24th May 2015, 3:28 pm
TomeiR
hope no damage was caused
12 Re: piping on 24th May 2015, 3:31 pm
gtir_pimp
Why did the boost pipe pop off? Not tightened or crap clamps?
If small weak clamps get some bigger stronger ones like mikalor.
Everyone should have decent clamps on the boost pipes especially when running a big turbo and more boost, but some people will spend big money on making the car go faster but neglect the smaller things that are just as important.
Can't a boost pipe popping off a car with a ball bearing turbo damage the turbo?
13 Re: piping on 24th May 2015, 4:38 pm
TomeiR
intercooling pipe. 1st time its ever happened. clamps are good popped off the rubber bit. updating as soon as i do fault code check
14 Re: piping on 24th May 2015, 7:54 pm
TomeiR
Done fault code check and no faults. Code 55.
15 Re: piping on 24th May 2015, 9:05 pm
TomeiR
I've tighten up everything. Idle is better. Now got a misfire. Spoke to ajay on the blower who was a great help. Tomorrow clamps and spark plugs required
