Gtir Motorsport club » General Discusion » Random banter » Rear arches!!!!
Rear arches!!!!
1 Rear arches!!!! on 2nd June 2015, 8:44 pm
pulsar23
Thought I would try and save myself some money and do the prep work myself and then get some1 to spray them.
Once I started I soon realised this wasn't going to happen lol
On a brighter note, I have rubbed down and undersealed the rear and removed some unwanted stuff !
2 Re: Rear arches!!!! on 2nd June 2015, 9:09 pm
pulsar23
Also how much are new 1s and where from?
3 Re: Rear arches!!!! on 2nd June 2015, 9:44 pm
http://www.carz2.co.uk/nissan-sunny-iii-hatchback-n14-199010-to-199507-1628a-15591-c.asp
4 Re: Rear arches!!!! on 2nd June 2015, 9:47 pm
Think they are at 20.88 each at the moment plus vat and delivery charge of 8.95 ....
5 Re: Rear arches!!!! on 2nd June 2015, 11:11 pm
pulsar23
well done
6 Re: Rear arches!!!! on 2nd June 2015, 11:14 pm
pulsar23
Have you used them before?
7 Re: Rear arches!!!! on 2nd June 2015, 11:21 pm
Thats where i got mine from dan. Bodyshop said they fit ok
8 Re: Rear arches!!!! on 2nd June 2015, 11:36 pm
pulsar23
@toaster55 wrote:Thats where i got mine from dan. Bodyshop said they fit ok
Cheers mate
9 Re: Rear arches!!!! on 2nd June 2015, 11:36 pm
No not yet  i will be very shortly ... im ordering both  arch panels and sills ...sills are just precaution  as il deal with anything  while il cut the arches out and get welding ... quite a few members have ordered from them already  stu  ... bones ... etc ..
10 Re: Rear arches!!!! on 3rd June 2015, 10:48 pm
pulsar23
Cheers lads
11 Re: Rear arches!!!! on 4th June 2015, 8:57 pm
No problems ... thats what we are here for Wink
why do you think its beyond your  capabilities mate ???
12 Re: Rear arches!!!! on 4th June 2015, 9:46 pm
pulsar23
Cos I have never welded lol and if I fill it then it will be back!!!
13 Re: Rear arches!!!! on 4th June 2015, 9:54 pm
Yeah only way to do it is cut the rust out .... i will do a how too when i do my arches ... for the welding side ... its not too difficult with a mig ... as its pretty much a beginner type thing and your only really tack welding as you cant get too much heat into the panel as it will distort it ...
14 Re: Rear arches!!!! on 5th June 2015, 10:29 am
FPSChris
How far did you get with cutting?
I've just started cutting bits off mine, I'm gonna take a go at welding the easy flat square bits behind the bumper. Anything with more shape will need body shop.
15 Re: Rear arches!!!! on 5th June 2015, 8:36 pm
pulsar23
I've been quoted 300 aside
16 Re: Rear arches!!!! on 5th June 2015, 9:29 pm
I dont know why everybody gets scared ... its only metal ... welds can be ground down .... cut the plate slightly small by 1mm all round and filler weld in tacks simple really no skill needed the only thing i reccomend is magnet holder helps keep it all in place really handy thing to have ...
17 Re: Rear arches!!!! on 5th June 2015, 10:26 pm
Edd China always uses the magnets lol
18 Re: Rear arches!!!! on 6th June 2015, 2:37 am
As said on phone the other day Dan........it's not hard to do just check measurements with regard to height as seen one that was done poorly with one rear arch lower than the other so simple but costly mistake once painted.
As Leighton said......it's not hard!
I'm no fantastic welder by a long shot but I can and have done it before to a standard of any good bodyshop.
cut and butt / tack weld the panels together or you'll get heat distortion and warpage, then just overfill and rub down and it's the rubbing down and contouring that's the hard bit and most important bit in order to get a good finish when painted, if your not confident with doing that part then sub that bit out to someone who can do it as end job will look naff if that's not done correctly
If we were not so damned busy and you can wait a bit I would have done the job for you, or you could have done it at our place yourself and I would have guided you along the way fella!
19 Re: Rear arches!!!! on 6th June 2015, 6:24 am
Like any welding get similar thickness metal and have a few practis attempts get used to what setting's wires speed heat suits the thickness and your welding style on that particular type of metal best so your not getting blast's ,snots or as said above distortion of the pannel
20 Re: Rear arches!!!! on 6th June 2015, 7:22 am
houghy_1
Out of interest where can u get replacement chassis rails?
21 Re: Rear arches!!!! on 6th June 2015, 9:58 pm
pulsar23
Like to watch it done first as never done it before but would love to try after! What is the best welder to start with?
22 Re: Rear arches!!!! on 6th June 2015, 10:37 pm
Mig welder .... pref anything from 180 amps and above .... as the lower amp machines tend to give poorer weld so it just looks like birdshit  lol ....  the 230 en turbo is a good machine sealey mig 180 is ok also  ... look at duty cycles as the cheaper machines  tend to have lower duty cycles wich means  you cant use it for long at higher amps ... beacuase your only tack welding the panel on it doesnt require to much skill  the skill is in cutting the rust out and cutting the panel to the correct size ... before you start .... tack welding is as it sounds  you are litteraly just placing a blob of weld to fuse the old metal to the new metal  anybody can hold the trigger on the gun and count 3 seconds  then move onto the next tack   ... welds can be ground down  too so its nothing to daunting  if it is abit ropey looking ... its all in the prep really like most things .... you got any pics of your arches  now ????
23 Re: Rear arches!!!! on 7th June 2015, 8:49 am
pulsar23
Yeah can I send to you to upload?
24 Re: Rear arches!!!! on 7th June 2015, 9:10 am
Yeah mate ....email or whattsapp.... pm me your number if you like ...
25 Re: Rear arches!!!! on 7th June 2015, 3:23 pm
pulsar23
I sent them?
