Gtir Motorsport club » General Discusion » Gtir related Discussion » Nissan Value Advantage Oil Filter
1 Nissan Value Advantage Oil Filter on 5th June 2015, 9:12 am
grim_d
Anyone came across this? Seems to be Nissan certified aftermarket parts, ordered a 15208-70J0A oil filter from a main dealer through ebay and was sent a 15208-095VA (E11 Note) Nissan Value Advantage Filter.
I'm sure that it will be interchangeable but it's not what I ordered and it's made in France so it's probably a Renault aftermarket part given that the Note will have a Renault engine, anyone got a new 70J0A that says where it's made?
Not a huge deal but I know the Nissan genuine filters are good and this one could have been made by anyone.
2 Re: Nissan Value Advantage Oil Filter on 5th June 2015, 12:01 pm
Bit tricky that as Nissan have quite a few OEMs for different parts of the world so for EU it likely Sogefi do them. I had Nissan filters from Japan mainly but they started doing them in a china factory so I went to BluePrint as quality seemed good on filter surface area & bypass valve & general construction/packaging consistently good, they made in Japan & price is very reasonable.
3 Re: Nissan Value Advantage Oil Filter on 5th June 2015, 1:00 pm
grim_d
Ill get in touch with them, my own fault really as bought based on item title but the description lists both numbers. Different seller on there doing a pack of 10 70J0A for £47 which is pretty good.
4 Re: Nissan Value Advantage Oil Filter on 5th June 2015, 6:47 pm
^ at £4.70 a filter it good if it the jap ones.
dunno why you got neg rep but I have equalled it out ...
5 Re: Nissan Value Advantage Oil Filter on 5th June 2015, 7:06 pm
grim_d
70J00 was made in UK, not sure about 707J0A, yeah its a decent price.
No idea mate, has happened a couple of times. Maybe im a bad egg.
6 Re: Nissan Value Advantage Oil Filter on 5th June 2015, 7:46 pm
Somebody probably hit the minus rep points button with sausage fingers ...
7 Re: Nissan Value Advantage Oil Filter on 6th June 2015, 1:15 am
Hope your not referring to my sausages Leighton lol
As Mr b says really graham
I've got genuine filters down here so will check where they are made as came from 3 different sources
8 Re: Nissan Value Advantage Oil Filter on 6th June 2015, 4:54 am
I am not the offender but  I phone is bad for it you swipe down the phone screen next thing normally positive but your reping people. Normally I notice and remove it but
9 Re: Nissan Value Advantage Oil Filter on 6th June 2015, 8:35 am
grim_d
Got in touch with the dealer, said to scrape the Value advantage sticker off, true enough it's a proper 70J0A, made in France, must have moved production in with Renault. Laughing
Anyway there's another Filter number to add to the list - 15208-095VA
10 Re: Nissan Value Advantage Oil Filter on 6th June 2015, 10:21 am
That will be sogefi group then. Should be good filters but still trust japanese manufacture more.
11 Re: Nissan Value Advantage Oil Filter on 6th June 2015, 11:15 am
As Mr B said I always stick to Blue Print saves the agro Smile
12 Re: Nissan Value Advantage Oil Filter on 6th June 2015, 11:31 am
grim_d
Maybe look at them next time.
