Gtir Motorsport club » Tech room » suspension set up & info » Best way to remove ball joints
26Best way to remove ball joints - Page 2 Empty Re: Best way to remove ball joints on 29th November 2015, 8:38 pm
no good when the monkey is sideways Laughing
27Best way to remove ball joints - Page 2 Empty Re: Best way to remove ball joints on 29th November 2015, 8:39 pm
Best way to remove ball joints - Page 2 Photo0552
lol I can remember having fun with that thing back in 2009!
28Best way to remove ball joints - Page 2 Empty Re: Best way to remove ball joints on 29th November 2015, 9:12 pm
Bigger the hammer the better Laughing
Digging through some old pics this morning shroom?
29Best way to remove ball joints - Page 2 Empty Re: Best way to remove ball joints on 29th November 2015, 9:35 pm
Yes indeed Very Happy nice looking back at things! If only I had kept the car standard I would have been so much better off haha oh well.
30Best way to remove ball joints - Page 2 Empty Re: Best way to remove ball joints on 29th November 2015, 9:37 pm
Haha never look back or at your bank statements, and owning an R is great Laughing
31Best way to remove ball joints - Page 2 Empty Re: Best way to remove ball joints on 29th November 2015, 9:40 pm
Yeah although current prices have risen my engine rebuild and turbo etc still out price its value :-(
32Best way to remove ball joints - Page 2 Empty Re: Best way to remove ball joints on 29th November 2015, 10:38 pm
That's normal though, cost of building a car unfortunately, cheer up Laughing
33Best way to remove ball joints - Page 2 Empty Re: Best way to remove ball joints on 30th November 2015, 3:34 am
I am about to cheat doing this, I have a 20Ton Press with a driver kit, that will get the fookers out.
34Best way to remove ball joints - Page 2 Empty Re: Best way to remove ball joints on 30th November 2015, 5:14 am
I got one of those supercheap presses, pretty small but should work ok for installing wheel bearings and other things.
35Best way to remove ball joints - Page 2 Empty Re: Best way to remove ball joints on 30th November 2015, 7:55 am
Woody, Is that the short leg 6 ton version. Good unit for what they are.
36Best way to remove ball joints - Page 2 Empty Re: Best way to remove ball joints on 30th November 2015, 8:05 am
Yeah its a the 6ton one, I just have it sitting on my work bench. It does the job but can be difficult with some things because it isn't very wide. For the price its worth it, they are always on special.
37Best way to remove ball joints - Page 2 Empty Re: Best way to remove ball joints on 30th November 2015, 9:22 am
Yep, handy unit for most jobs and as you say, width is the only downfall, but hey, bang for buck Smile
38Best way to remove ball joints - Page 2 Empty Re: Best way to remove ball joints on 23rd June 2019, 4:26 pm
wingzerojm
wingzerojm
@Mr B wrote:They nothing unusual it just as nissan wanted sell whole arm & R not a big seller the bj got over looked in patern parts rather than not being available from manufacturers. I seen a few people say about welding & few not. is really down to what joint you get & the brand too as the spec size differs a little thus the interference fit could be too low in worse case scenario. I found brands like delphi & 555japan & Moog K9633 with no knurling spline on the fit area far better interference tolerance over real cheap monkey metal brands .
Basically OEM arm bore is 38.0mm, due to hole deformation/stretch from re-use & clean up from corrosion you need joint around 38.2mm minimum for good interference, Delphi TC600=38.2mm, Moog K9633=39.2mm will work if ream bore out to 38.8, they have grease nipple, innovative boot & very good quality, FAI SS1163 should work as well but not used or measured them .
much prefer the bolt on lower joints over press fit but they not used much these days as it all going towards full arm :-/ done ones on 206 hdi today what a cock those arms are hidden in the subframe  with bolts from top with not enough room to fully lift bolts without hassle, f00king french engineers :-S can work easier on an R with one arm than 206 with 2 arm :-P
just wanna say, this is a 4 year old post but i found it very very useful..thanks!
39Best way to remove ball joints - Page 2 Empty Re: Best way to remove ball joints on 24th June 2019, 12:48 am
Mr B and his wealth of knowledge Laughing
