This is a direct view/download of files I got on Google Drive on the R.
Most of this stuff is available else where but an all in one source can be useful plus use it or link to it how you like as I will not complain unlike another forum did on workshop manual on a file host :-/ !
GTiR Nissan FAST.rar
Autodata 2011.docx
Nissan Data Scan I 1.62 .zip
OBD1 Scan Tech Nissan.rar
ECUTalk.zip
OBD1 14pin consult cable - links.docx
GTI-R NME Group-N Manual.pdf
Gp.A_RNN14.pdf
Self Diagnosis Mode I & II.pdf (ecu fault codes)
RNN14 front wishbone (transverse link) OVERHAUL.pdf
RNN14 clutch hydraulics, master & slave service parts.pdf
CLUTCH FORK PLATING.PDF
Service_Manual_Nissan_Pulsar_1990_Volume_1.pdf
Service_Manual_Nissan_Pulsar_1990_Volume_2.pdf
FUSE BOXES.PDF
ECU PIN-OUTS.PDF
Nissan Radio Harness Wiring.PDF
RNN14 Lifting Jacking & Stands.pdf
RNN14 Parking Brake Cables, cross part numbers.pdf
GTiR Fluid Capacities.txt
S&E CATALOGUE gtir_part_nos.pdf
WHEEL_SPEED_SENSOR.PDF
TURBO.PDF
THROTTLE_CHAMBERS.PDF
TPS DETAILS.PDF
THROTTLE_BODIES.PDF
SUSPENSION_REAR.PDF
SUSPENSION_FRONT.PDF
STEERING.PDF
54C CYLINDER BLOCK TORQUES.PDF
ECU WATER TEMP DIAGNOSIS.PDF
RADIATOR FAN CONTROL ECU SPECS.PDF
SERVICE_DATA_SPECS_VOL2BPDF.PDF
SERVICE_DATA_SPECS_VOL2APDF.PDF
SERVICE_DATA_SPECS_VOL1BPDF.PDF
SDS_SERVICE DATA & SPECIFICATIONS_VOL1.PDF
REAR_SPOILER.PDF
HORIZONTAL REAR WIPER.PDF
POWER_WINDOWS.PDF
LIFTING.PDF
INTERIOR.PDF
INPUT_SHAFT.PDF
GEARBOX SHAFT SHIMMING.PDF
IDLE_ADJUSTMENT.PDF
HARNESS_TERMINALS.PDF
GAUGES.PDF
ENGINE_EMISSION_CONTROL2.PDF
ENGINE_EMISSION_CONTROL1.PDF
ENGINE.PDF
ECU_INSPECTION.PDF
ECCS_DIAGRAM.PDF
DRIVE_BELTS.PDF
DOOR_MIRRORS.PDF
DIAGNOSTIC_PROS_26_35.PDF
DIAGNOSTIC_PROS_16_25.PDF
DIAGNOSTIC_PROS_06_15.PDF
DIAGNOSTIC_PROS_01_05.PDF
DIAGNOSTIC_PROCEDURES_INDEX.PDF
DET_SENSOR.PDF
AIR FLOW METER DIAGNOSES.PDF
DASH.PDF
CYLINDER_BLOCK.PDF
CLUTCH.PDF
ABS_DIAGNOSIS.PDF
CLIPS_FASTENERS.PDF
CIRCUIT_CAR.PDF
CARGO_GLASS.PDF
TRANSMISION_ADJUSTMENT_PROCEDURE.PDF
GEARBOX - TRANSFER BOX OIL SEALS.PDF
GTiR ADL BLUEPRINT part nos.pdf
J3 NME.PDF
GTiR Standard Cam Timing Spec.pdf
Autodata 2011.docx
ECUTalk.zip
Gp.A_RNN14.pdf
FUSE BOXES.PDF
ECU PIN-OUTS.PDF
TURBO.PDF
TPS DETAILS.PDF
THROTTLE_BODIES.PDF
SUSPENSION_REAR.PDF
STEERING.PDF
REAR_SPOILER.PDF
POWER_WINDOWS.PDF
LIFTING.PDF
INTERIOR.PDF
INPUT_SHAFT.PDF
IDLE_ADJUSTMENT.PDF
GAUGES.PDF
ENGINE.PDF
ECU_INSPECTION.PDF
ECCS_DIAGRAM.PDF
DRIVE_BELTS.PDF
DOOR_MIRRORS.PDF
DET_SENSOR.PDF
DASH.PDF
CYLINDER_BLOCK.PDF
CLUTCH.PDF
ABS_DIAGNOSIS.PDF
CLIPS_FASTENERS.PDF
CIRCUIT_CAR.PDF
CARGO_GLASS.PDF
J3 NME.PDF
