Gtir Motorsport club » General Discusion » Gtir related Discussion » Copper washers
Copper washers
1 Copper washers on 5th July 2015, 7:32 am
Ok so I suppose it differs slightly but this is the second time and I would not say I was under or over tightening what copper washers do you lads use on the turbo and the banjo bolts to block ?
Want some spares for different kinds of brakes so what copper washers you using on them ?
2 Re: Copper washers on 5th July 2015, 7:41 am
Gtirchris
Nissan ones for me, but I guess you would be able to get most of the popular sizes from a motorfactors or plumbers merchant
3 Re: Copper washers on 5th July 2015, 12:37 pm
for oil lines etc look at trying dowty bonded seals if getting constant issue.
I have a set of copper washers like in link below & had them a few years & few jobs without issue.
http://www.screwfix.com/p/ring-automotive-copper-sealing-washers-240-pieces/12460
4 Re: Copper washers on 5th July 2015, 1:40 pm
grim_d
If you are re-using copper sealing washers you can anneal them with a blowtorch to help them seal again.
Bonded seals are good too, see them at work in certain places but I bet they are expensive!
5 Re: Copper washers on 5th July 2015, 6:31 pm
Im with Mr B on the dowty washers. My copper washers kept weeping, replaced them with dowty ones and not had any leaks in 4 years
6 Re: Copper washers on 5th July 2015, 6:52 pm
Nice one no I never reuse stuff new every time on things like that. Mr b link ones I find them just off the right size and the lip very thin.
7 Re: Copper washers on 5th July 2015, 8:26 pm
I never had any major problem with them copper crush washers, did have a banjo on some brakes once that wept & only stopped on 3rd fitting of new washers. most causes of weeping is scores, grooves & shit on the joint faces.
Dowty bonded seal types can be had in most hydraulic & engineering type outlets & they quite cheap around 30p to a £1 for bigger size ones, most stuff for car use would be 30 to 70p a seal generally, bet moley got access to loads of them :-)
8 Re: Copper washers on 5th July 2015, 9:46 pm
Not sure if my company stock them, if not I know a supplier locally. I will be replacing all mine again on the rebuild.
9 Re: Copper washers on 5th July 2015, 10:39 pm
There is plenty on ebay also ... aslong as you know what size your after ...
