Gtir Motorsport club » General Discusion » Gtir related Discussion » Alternator regulator
1 Alternator regulator on 8th July 2015, 7:40 pm
Are the regulators built into the alternators on the r's some one said they are and some one has said there not! Starting getting high volt readings (around 17v) then the lights popped! Then starting running crap, then the abs light and brake warning light came on and now won't start, so must be the alternator
2 Re: Alternator regulator on 8th July 2015, 7:53 pm
Best way of putting it is regulator is integrated into the alternator, quite easy & cheap to fit new regulator & brushes to alternator if bearings & shaft in decent order.
Complete new cheap brand Alternators can be had for under £50 & decent rebuild probably around 50 to 100 GBP.
would be worth disconnecting alternator, run from good battery & testing start as you may of damaged fuses or electronics if unlucky ...
3 Re: Alternator regulator on 8th July 2015, 8:06 pm
Where can you get a new alternator from for £50?? Iv been quoted £160 from my local parts place
4 Re: Alternator regulator on 8th July 2015, 8:12 pm
http://www.gtir-motorsport-club.com/t4979-new-alternator-starter-motor
ones on ebay can be had for less than £50 if put in offer.
Starter & alternator co do genuine new for 110GBP delivered & no exchange as new not recon.
5 Re: Alternator regulator on 8th July 2015, 8:15 pm
Cheers, just had a look, may be a daft question but these will 100% ok for the Gtir as doesn't state so...
6 Re: Alternator regulator on 8th July 2015, 8:23 pm
Yes, alternator is just a standard A957 model, have used starter alternator co myself for many years they good company, ebay is cheaper manufacturer of same alternator design, would want know manufacturer before I would commit to buy
7 Re: Alternator regulator on 8th July 2015, 8:35 pm
Iv put a bid in any way, see what happens! Cheers for the help pal
8 Re: Alternator regulator on 8th July 2015, 8:40 pm
best of luck ...
9 Re: Alternator regulator on 8th July 2015, 10:31 pm
Recon on a exchange basis is about £80 at my local motorfactors or bob will have one
10 Re: Alternator regulator on 10th July 2015, 12:46 pm
Ok just so people know this doesn't actually fit properly, it's different where the bolt goes through to tighten the belt up if that makes sense? It can't even be made to fit as its too different. So going to try and send it back Sad
11 Re: Alternator regulator on 10th July 2015, 8:56 pm
which one was that ! the ebay one ? if it A957 it should be fine as that what I always use. what make is it !?
12 Re: Alternator regulator on 10th July 2015, 9:11 pm
Yes the eBay one I followed the link too, not sure on the make just says Nissan on the side. But deffo doesn't fit!
