Gtir Motorsport club » General Discusion » Gtir related Discussion » Oil filter thread size
1 Oil filter thread size on 13th July 2015, 6:08 pm
Whats the thread size of oil filter on a GTiR? Im fittin a oil cooler & I need to get a centre bolt that go's threw the sandwich plate & then screw the filter on... But cant find the thread size?
And anyone know where I can get 1 from before weekend? Cant find 1 anywhere suicide
2 Re: Oil filter thread size on 13th July 2015, 6:20 pm
Iv all ways heard there a bit of a waste of time on our cars gaz? Any reason for it?
3 Re: Oil filter thread size on 13th July 2015, 6:35 pm
3/4UNF, the sandwich plate & centre threaded fitting is same as the VW ones such as golf gti corrado. I think the mocal part# for whole sandwich plate thermostatic was OTSP1-3/4UNF
4 Re: Oil filter thread size on 13th July 2015, 7:17 pm
Gti-r dannyboy
I burst the pipe on my oil cooler by missing a gear change once took a hole second for my oil to leave the engine killed the engine there and then. Have been told dont bother unless your taking it on the track and its 30plus degres
5 Re: Oil filter thread size on 13th July 2015, 7:45 pm
Its just on hot days realy... 5 mins of boost on a country road or chasing someone thdn temps start rising, so was going to fit 1...
Cheers Mr B Smile
6 Re: Oil filter thread size on 13th July 2015, 8:14 pm
A lot of people don't need them & in uk it not that hot so can manage without.
decent thermostatic one with say a 230mm 16 row cooler & decent hoses should be trouble free. I only use hydraulically crimped fittings on decent braided hose from local hydraulic shop as burst points & leaks tend be unheard of that way.
7 Re: Oil filter thread size on 17th December 2015, 5:02 pm
http://www.ebay.co.uk/ulk/itm/231559686133
http://www.ebay.co.uk/ulk/itm/331540460179
Which one is the right one please?? Need to order it
8 Re: Oil filter thread size on 17th December 2015, 5:46 pm
From what i gather it depends on what size hoses you have to your cooler as to which one you go for ????
9 Re: Oil filter thread size on 17th December 2015, 6:02 pm
I wasn't sure if that was anything todo with the screw inside the sandwich plate, how would I even measure them?
10 Re: Oil filter thread size on 17th December 2015, 7:55 pm
from your other thread you say you already got the plate & only want the centre bolt which is as linked below from MLR
http://www.mattlewisracing.co.uk/product.php/898/0/oil_cooler_plate___matt_lewis_racing/3b6cb3761b0a2298d00ec2d48352728b
If you do need whole plate & already have pipes then you will need measure fittings they have & match them, use vernier caliper & thread gauge or test on some fittings or get a local shop check them.
11 Re: Oil filter thread size on 17th December 2015, 8:10 pm
I've checked the sandwich plate and it's not thermostatic and that's what I'm after....I'll have to get them measured up, cheers b
12 Re: Oil filter thread size on 17th December 2015, 8:23 pm
does the other plate have fittings that could be swapped if needed to new thermostatic plate !
Is indeed best check but in worse case scenario you probably going have enough parts between what you got & get to make it all fit .
13 Re: Oil filter thread size on 24th December 2015, 1:28 pm
Right, I have the thermostatic sandwich plate, and the fittings to connect it to the the pipes for the cooler are correct, so that's fine, however I bought it with the 3/4 unf center adaptor, ive also bought a genuine Nissan oil filter (sunny n14 turbo it says on the add) and it won't thread onto the adaptor as its the wrong size, is the filter wrong or this 3/4 unf jobby?
14 Re: Oil filter thread size on 24th December 2015, 2:12 pm
3/4-16 Unf is filter thread I think
15 Re: Oil filter thread size on 24th December 2015, 2:15 pm
http://www.ebay.co.uk/ulk/itm/131680974392
This is the oil filter I've received, is this right?
16 Re: Oil filter thread size on 24th December 2015, 2:17 pm
Looks like it whats it say on the side of the box
17 Re: Oil filter thread size on 24th December 2015, 2:27 pm
So now I'm wondering why doesn't it bloody fit! I got the 3/4unf thread as stated
18 Re: Oil filter thread size on 24th December 2015, 2:45 pm
I brought a filter off eBay and was a bag of sh1t although it said on the box no way would it seal. Stick with genuine nissan or blueprint no and looks like it is genuine from the link so god knows wht it wont fit.
I think the car just hates you Pete maybe best to leave it alone lol
19 Re: Oil filter thread size on 24th December 2015, 2:54 pm
Tom, it doesn't hate me, it loves me, but she's a high maintanence bitch that's pissing me off, I just want the oil filter to fit on the God damn thread fuming
20 Re: Oil filter thread size on 24th December 2015, 3:30 pm
So dose that filter fit the existing screw thread
21 Re: Oil filter thread size on 24th December 2015, 4:14 pm
That I don't know yet Johnny, but I'll find out in a few days when I go to the garage to the car
22 Re: Oil filter thread size on 28th December 2015, 4:42 pm
How did you get on with it .... did you manage to check the old filter on the new thread and visa versa ????
23 Re: Oil filter thread size on 28th December 2015, 4:46 pm
No I got the dash out today but couldn't be bothered to do anything else, I will check this week though
24 Re: Oil filter thread size on 28th December 2015, 5:31 pm
What you ripping the dash out for ????
25 Re: Oil filter thread size on 28th December 2015, 7:28 pm
Having it flocked, also fitting some new gauges so it'll make that easier
