Gtir Motorsport club » Tech room » Gearbox section » Gearbox oil
Gearbox oil
1Gearbox oil Empty Gearbox oil on 13th July 2015, 6:50 pm
boydy
boydy
Could anyone tell me if the gearbox and transfer box hold the same oil and if so do i just fill the gearbox up to the level and itul run threw to the transfer box or do i fill the gear box up and the transfer box up sepertly. Ive just had them off the car as the gearbox has been in bits for a repair and bybthe looks of it the oil would run threw from the box but just wanted to make sure.
Cheers
2Gearbox oil Empty Re: Gearbox oil on 13th July 2015, 7:34 pm
Same spec oil, good one for sensible price & quality is Millers CRX 75/90
gl4/5 spec, syncro & most lsd type friendly too.
easily available in UK so prices can be good if shop about or even opie oil if got good discount code ...
Gearbox 4.2L
Transfer 1.5L
Rear Diff 1L
Gearbox & transfer is separate drain plugs & fillers.
3Gearbox oil Empty Re: Gearbox oil on 13th July 2015, 9:42 pm
boydy
boydy
Ok great stuff thanks for your help pal
4Gearbox oil Empty Re: Gearbox oil on 6th August 2015, 7:04 pm
Mr B killing 2 birds with one stone in this post as I was just about to search how much fluid the gearbox holds
5Gearbox oil Empty Re: Gearbox oil on 6th August 2015, 8:08 pm
I think there is a sticky for how much oil ....
6Gearbox oil Empty Re: Gearbox oil on 22nd September 2015, 5:36 am
DaniRS
DaniRS
Hi, have a little question.
I mounted the front modena torsen diff, which oil should I put in? The same of gearbox? Or in transfer a specific oil for LSD?
7Gearbox oil Empty Re: Gearbox oil on 22nd September 2015, 7:27 pm
^ 75w90 gl5
8Gearbox oil Empty Re: Gearbox oil on 22nd September 2015, 9:47 pm
DaniRS
DaniRS
@Mr B wrote:^ 75w90 gl5
For Torsen is not required a LS oil?
9Gearbox oil Empty Re: Gearbox oil on 22nd September 2015, 10:28 pm
torsen is gear driven so no need, when I got one modena stated any good 75w90 gl5 synthetic would be suitable.
10Gearbox oil Empty Re: Gearbox oil on 22nd September 2015, 11:14 pm
I have used a shock proof oil in my nismo diff as it takes some of the snatchiness away from it
But will be fine as Mr B said on 75w/90
11Gearbox oil Empty Re: Gearbox oil on 23rd September 2015, 5:18 am
DaniRS
DaniRS
@Mr B wrote:torsen is gear driven so no need, when I got one modena stated any good 75w90 gl5 synthetic would be suitable.
Thanks Mr. B!! Very Happy This is the answer i needed!
12Gearbox oil Empty Re: Gearbox oil on 23rd September 2015, 5:56 am
And if you don't use the Miller's, get Castrol Syntrax 75/90W.
You may as well do the rear diff at the same time, because it is probably in need of some good oil as well.
