Gtir Motorsport club » General Discusion » Gtir related Discussion » Gear linkage rubber boot
1Gear linkage rubber boot Empty Gear linkage rubber boot on 14th July 2015, 7:49 pm
Hi,
I phoned Nissan today to order various parts, one that I needed is the boot cover that fits where the gear linkage bolts to the gearbox:
Gear linkage rubber boot Striker%20boot_zps21i5ljbn
But its no longer available.. Part number i gave was 32859-03E01, section 328
Does anybody know of a boot cover that can be used off another vehicle? Mines knackered and fell to pieces years ago..
On a plus side ordered my new suspension with Bob today Very Happy will be a rolling chassis soon cheers
Gaz
2Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 14th July 2015, 9:48 pm
Should still be able get that, that boot 'striking rod boot' is used on a load of nissan models.
nengun do it >
http://www.nengun.com/nissan/nissan-pulsar-gti-r-oem-parts
easily found in the US of A >
http://www.infinitipartsusa.com/Infiniti-Part-Number-32859-03E01-p/3285903e01-.htm
Could be worth asking ICP as they quite good for the UK.
3Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 14th July 2015, 9:58 pm
Beat me to it mr b .... was on the search and quite a few nissan models use them ...
4Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 14th July 2015, 10:05 pm
^ yeh i'm very surprised they said not available, I had one along with the seal & some other bits about 8 months ago & boot was stocked as covers lots of models & is quite common to be done along with seal as they often leaking & boot shredded.
5Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 14th July 2015, 10:08 pm
Cheers guys, will give them another try tomorrow, I didn't speak to the lad I normally deal with today Evil or Very Mad got the impression he couldn't be arsed looking!
Gaz
6Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 14th July 2015, 10:28 pm
Sounds like the usaul parts department attitude...Evil or Very Mad
7Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 14th July 2015, 10:31 pm
If you google search "nissan part number 34130Y"  it will come up with other nissan models wich might help you out if it draws a blank with the pulsar ...
8Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 15th July 2015, 7:29 pm
Spark plug spike
Spark plug spike
One on ebay mate.
http://www.ebay.co.uk/itm/Nissan-Pulsar-Gtir-Boot-Rod-Gearbox-Sunny-N14-/252027447989?pt=LH_DefaultDomain_3&hash=item3aae01aab5
9Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 15th July 2015, 8:29 pm
@Spark plug spike wrote:One on ebay mate.
Cheers, I ordered one from Nengun yesterday, never thought to look on ebay Mad
Gaz
10Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 15th July 2015, 8:46 pm
^ how much was Nengun delivered.
use to be a few constant 'buy it now'on uk eBay around £4, boot that price from Nissan
11Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 15th July 2015, 9:00 pm
£11 Mr B, tad expensive but got a few more things to make it worth while Although it was cheaper with postage than the one on ebay, just take longer to arrive.  Saw 5zigen Pro Racer ZZ on there, got tempted but the delivery would be expensive to have that shipped!
Gaz
Edit: sorry delivery was £11!
12Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 15th July 2015, 9:16 pm
Mmm quite expensive, possibly USA cheaper ... not something you buy often anyway.
13Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 15th July 2015, 9:24 pm
Think I looked at the USA link, but delivery was really high. I ended up getting other oil seals as well so the whole order delivered was 25.88, think its been the cheapest order this week up to now!
Just checked for the 5zigen, delivery by dhl £176 Shocked
Gaz
14Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 15th July 2015, 9:45 pm
hreggtir
hreggtir
I might have one of them mate. I got one from Nissans not even a year ago i'll have a look
sorry I have part no. 32869 bush fork sft. but I had a leak from there so I ordered a few bits, obviously used the seal, must have used the boot as well,
15Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 10th May 2016, 7:22 pm
Finally got round to replacing the boot tonight, but for the life of me I couldn't get the roll pin out, 32898 in the top picture. I'm thinking of applying heat then trying again with a drift and knocking stick again.
Has anybody else replaced this? Sure I reassume one on here having the same problem...
Gaz
16Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 11th May 2016, 8:52 pm
So got the yoke off finally Laughing with the help of my favourite gas, Mr Map. Heated the roll pin and it popped out easy, didn't realise there were two roll pins one inside the other!
Gear linkage rubber boot 45A1674F-FFCC-4476-A45C-47720D5E18F0_zpsbpheaen5
Gear linkage rubber boot AA09D532-4EDB-4DA5-816E-26D845AC9910_zpsl3ko0pqa
Once the roll pins were removed, more heat applied to the yoke, then a small gear puller to remove it, cleaned up the shaft applied some grease and it pushed straight back on. Another job ticked off the list.
Gaz
17Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 11th May 2016, 9:23 pm
Very nice, I might add this one to my list now I've seen you do it lol
18Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 11th May 2016, 9:28 pm
Bit of a twat to do but needed doing as this what was left of the original
Gear linkage rubber boot F11C4C86-8726-4C8D-8748-E9F1D9C5631B_zpsmkfyuuzu
Don't know if it would be a mot failure over here, but the lack of the dust boot not the best!
19Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 11th May 2016, 9:44 pm
Yeah, that roll pin's a right bastard to remove,
Refitting the rubber gator is a twat of a job too,
Evil or Very Mad
20Gear linkage rubber boot Empty Re: Gear linkage rubber boot on 11th May 2016, 9:52 pm
I thought mine looked average mate, but yours is destroyed lol
