Gtir Motorsport club » Tech room » Help and Advice » alternator bracket
alternator bracket
1 alternator bracket on 16th July 2015, 5:35 pm
joetheeskimo
Hi guys
I know a lot of parts are standard across multiple nissan but does anyone know if the bottom alternator bracket. The one that connects to the block is standard..I'm after one but refuse to pay nissan prices for a new one.
2 Re: alternator bracket on 16th July 2015, 6:06 pm
17 !?
Almera gti, almera tino, primera, sunny gti
http://nissan4u.com/parts/info/1171053J10/
3 Re: alternator bracket on 16th July 2015, 6:09 pm
joetheeskimo
@Mr B wrote:17 !?
Great thank you, next question is about wiring of the starter motor. There is two screw terminals, are these both for live and if so are they both on the same loom.
4 Re: alternator bracket on 16th July 2015, 7:40 pm
should be one main stud terminal near the 2 pin plug, this stud is the large +
smaller fitting is for earth
5 Re: alternator bracket on 16th July 2015, 8:41 pm
Dont forget the trigger wire mr b .....
6 Re: alternator bracket on 16th July 2015, 10:00 pm
7 Re: alternator bracket on 16th July 2015, 10:17 pm
@joetheeskimo wrote:Hi guys
Why buy new sure plenty people have spare ones bob probably has one
8 Re: alternator bracket on 16th July 2015, 11:54 pm
He means startermotor Mrb not alternator I think
Got a bracket you can have for free Joe, il reply back to pm with bits probably Sunday or Monday as can't get bits out till then anyways as I'm away tomorrow at donnington
2 pole terminals on the back of solenoid (as you look at it from rear) the left one goes directly to startermotor the other goes to main thick live wire, the spade connection I believe is the small black and white wire
9 Re: alternator bracket on 17th July 2015, 1:34 am
^ Ah so he does, overlooked 'starter motor' in his second question & assumed he still on alternator Q&A :-S
10 Re: alternator bracket on 19th July 2015, 8:31 am
joetheeskimo
@GTI-R US wrote:He means startermotor Mrb not alternator I think
Thanks Bob thats helped a lot, thanks.
