Gtir Motorsport club » Tech room » Help and Advice » Injector filters
Injector filters
1 Injector filters on 17th July 2015, 11:48 pm
Got some new injectors that are based on a Bosch injector. If I drop the filters into the top in the direction in the picture, is that correct?
2 Re: Injector filters on 18th July 2015, 12:44 am
Other way.
3 Re: Injector filters on 18th July 2015, 12:53 am
Thanks mate thumbsup
4 Re: Injector filters on 18th July 2015, 1:43 am
Once bolted up they shouldn't be a super tight fit should they? Still be able to twist the injector left to right etc?
5 Re: Injector filters on 18th July 2015, 3:42 am
I used these type with extenders. I think they will be fine.
6 Re: Injector filters on 18th July 2015, 6:39 am
Mine are standard parts but is it worth getting them cleaned? How much is it and how do they clean them?
7 Re: Injector filters on 18th July 2015, 11:52 pm
Supernova
@Bones wrote:Mine are standard parts but is it worth getting them cleaned? How much is it and how do they clean them?
Not used them myself but I noticed they cleaned Injectors whilst I was browsing through their site. Maybe worth a look into and if you use them let us know if they are any good.
http://www.efi-parts.co.uk/index.php?productID=332
8 Re: Injector filters on 19th July 2015, 7:41 am
Lots of people clean injectors I used a place near me. Few companies you send them away. You get a flow sheet of before and after and I guess it's just ultrasonic parts cleaner then spray a cleaner through them
9 Re: Injector filters on 19th July 2015, 8:00 am
Is there anywhere I can buy new o rings for standard injectors as one of mine had started leaking but temporary fixed it with some ptfe
10 Re: Injector filters on 19th July 2015, 8:09 am
Yes mate they pop up on e bay so will be availible else where. They do kits with the pinochle caps aswell
11 Re: Injector filters on 19th July 2015, 8:18 am
Ultrasonic cleaner  while sending a pulse through the injectors  otherwise it wont clean them through ...
12 Re: Injector filters on 19th July 2015, 8:52 am
Supernova
This may also may be handy for you guy's.
Also be wary about ordering Injector seal kits from ebay as I've ordered a set 3 weeks ago and have yet to receive or had a reply to my messages.
