Gtir Motorsport club » Tech room » Help and Advice » May be auto electrician time
1 May be auto electrician time on 19th July 2015, 11:17 am
Right have.a go at this one lads, fully charged me battery and put it on the car the yesterday ready to go to the show, started and ran fine, spent the day with you lot only to return to the car to find it turned over very very slowly but did start. Drove home fine turned off at my home then tried to start it again and it turned over nice and fast and started so I disconnected the + ~ and left it over night this morning re connected the battery and hardly turns the car over. The battery is a month old and the Nissan alternator is a month old. I've cleaned as many earths as I can find and the alternator is charging at 14.7 volts
2 Re: May be auto electrician time on 19th July 2015, 11:59 am
Could be poor connections/corrosion inside cable ends or perhaps starter not too healthy.
Check battery voltage to be sure seem good & reads above 12.5V, also with neg voltmeter clamp left on battery check voltage at starter to determine if got voltage drop, check earth too, even adding a jump lead from bat- to engine/starter can be quick way conclude earthing issues, can do same with jump leads with positive but not so easily on a pulsar. Starters with issues tend draw more current so you may find cables appear get overly hot when cranking, inductive ammeter is useful here to see amp draw of cranking starter.
Should be quite easy draw some conclusion.
3 Re: May be auto electrician time on 19th July 2015, 12:52 pm
Mine always turns over very slowly when the engine is cold. Some times I'm not sure it's going to make the first turn, but it always keeps going and starts.
When the engines cold it take a lot more effort to turn over so the starter/battery have to work a lot harder. I even got a new starter from Bob about a year ago because of the problem but as the old one keeps going I've never changed it..
4 Re: May be auto electrician time on 19th July 2015, 2:59 pm
Indy
It could be a faulty battery which is covered under warranty or a bad/ loosely connected terminal
Just make sure they are tight or have the battery replaced do the free stuff first ....... It's an Indian thing as u are aware of now
5 Re: May be auto electrician time on 19th July 2015, 4:21 pm
If you have one, carry out a hydrometer test on the battery?
6 Re: May be auto electrician time on 19th July 2015, 6:51 pm
Battery is totally sealed but its been on charge for about 6hrs and is still only showing 11.7 volts so ive out it on a different battery charger to rule that out and we will see. Hoping its that then i can exchange it for free. Now thats a indian thing indy lol. Wobbling my head all the way lol
7 Re: May be auto electrician time on 19th July 2015, 7:09 pm
oh blimey sir!
Battery looking very suspect & would be nice easy free fix ...
Only 2 brands of battery I bother with are Banner & Yuasa
8 Re: May be auto electrician time on 19th July 2015, 7:30 pm
I got this from halfords as it has a 3 year guarantee and I know lots of people say these cars eat battery's but halfords are always great at exchanging stuff hassle free. Plus I know the bloke that works there as I use to work with him on Sunday's when I was an apprentice 24 years ago! Bloody hell
9 Re: May be auto electrician time on 19th July 2015, 11:51 pm
As said yesterday Darren if it's not the battery then more than likely the startermotor
The only other possibility is a leak from the head gasket where water is entering the cylinders overnight so on initial start up too much compression as water will not compress but that's if everything prior does not work
10 Re: May be auto electrician time on 20th July 2015, 3:25 pm
Right after a bit more digging it seems I can't get the battery to hold more than 11.7 volts and that was after being on charge all day so just checked it now after being left alone all day and it's 10.6 so luckily it's loosing power itself sat on the bench so hopefully problem solved
11 Re: May be auto electrician time on 20th July 2015, 5:05 pm
Just took it back to halfords, they checked it and it has a cell down but fair play to em they swapped it straight away no problem
12 Re: May be auto electrician time on 20th July 2015, 5:07 pm
Least it was a simple fix
13 Re: May be auto electrician time on 20th July 2015, 5:16 pm
Mr B I have one of those meters that clamp on the power lead and tell you how many amps its drawing but what would it be reading when cranking ?
14 Re: May be auto electrician time on 20th July 2015, 5:33 pm
Glad to hear it was the battery i hate bloody electrics Evil or Very Mad
15 Re: May be auto electrician time on 20th July 2015, 5:37 pm
9 - 10 volts on an average darren ....
16 Re: May be auto electrician time on 20th July 2015, 5:48 pm
I worked at halfords years ago ... They had batteries on the shelf that were years old ..
Your battery could have been years old when you bought it
17 Re: May be auto electrician time on 20th July 2015, 7:15 pm
@nomad wrote:9 - 10 volts on an average darren ....
I think he meant draw, I would of thought around 100amps?
18 Re: May be auto electrician time on 20th July 2015, 8:52 pm
Yeh over 100amps, more likely region between 120 to 200amps.
compression ratio, oil viscosity & hot & cold climate make massive differences .
