Gtir Motorsport club » Tech room » Help and Advice » gearbox plugs
gearbox plugs
1 gearbox plugs on 19th July 2015, 12:24 pm
Can anyone help!
both the drainage and refill plugs are seized solid on my gearbox and I lost some fluid when cleaning the box so need to top it up. There is a small plug on the top back of the gearbox behind the breather (between the rear stabilise) can this be used to top up?
2 Re: gearbox plugs on 19th July 2015, 3:01 pm
Indy
Hi they may seem seised but mine were fing tight as hell so just try undoing em I had an extension on an extension when undoing mine
3 Re: gearbox plugs on 19th July 2015, 4:27 pm
people go silly tight on these, best adding bit of ptfe tape on them as a:it stops leaks & means don't need do um up silly tight b:reduces corrosion issues between alloy & steel .
You could try adding a little oil via breather just keep you running but ideally those plugs need come out even if needs old modded extension welded in them. First off try a proper drain socket tool in nice cleaned out plug .
Pain in the ass them them plugs at times :-/
4 Re: gearbox plugs on 20th July 2015, 11:37 pm
By the looks of things someone has used something to seal them in and they are solid. Was using a breaker bar and drain plug tool but no joy, so for time being I used the plug on top to top it up with 1/2ltr
5 Re: gearbox plugs on 20th July 2015, 11:55 pm
maybe some heat will help soften any bond on threads.
