Gtir Motorsport club » General Discusion » Gtir related Discussion » T28 ball bearing turbo?
1 T28 ball bearing turbo? on 21st July 2015, 3:35 pm
Is the standard t28 in the gti-r a rollerbearing turbo? im convinced its a journal bearing but someone else says its roller?
N14 GTi-R (1990-94) T28:
Compressor: T3 Super-60, 60 trim 60mm 0.60 A/R BCI-1 compressor.
Turbine: T-25, 79 trim 53.8mm 0.86 A/R turbine housing, Inconel Turbine Wheel.
Stock Boost: 7 psi
Safe Boost: > 13-15 psi After that The Turbo is past it's efficiency
Max Boost: 17 psi
HP Ratings: 290 - 300 RWHP
Type of Bearings: Journal Bearing
Upgrades: Replace compressor Housing w/ S14 T28 and Max RWHP can be bumped upto 320
Guy refers to the T28r as being rollerbearing turbo?
2 Re: T28 ball bearing turbo? on 21st July 2015, 4:01 pm
Sure standard isn't roller
3 Re: T28 ball bearing turbo? on 21st July 2015, 4:11 pm
Yeah i searched around and everywhere say its not
4 Re: T28 ball bearing turbo? on 21st July 2015, 4:23 pm
Standard isnt roller bearing.
The hybrid ones are roller bearing.
5 Re: T28 ball bearing turbo? on 21st July 2015, 4:42 pm
yeah thought so, thanks Smile
6 Re: T28 ball bearing turbo? on 21st July 2015, 5:29 pm
some hybrids are just 360° journal thrust rather than standard which is 270° journal bearing.
7 Re: T28 ball bearing turbo? on 21st July 2015, 6:59 pm
Probably had it rebuilt
8 Re: T28 ball bearing turbo? on 21st July 2015, 8:53 pm
lenzo
No t25 is roller bearing
You can get a conversion done which is ball bearing from Owens development
9 Re: T28 ball bearing turbo? on 22nd July 2015, 7:55 am
yup the gti-r is a high flow turbo according to some source? i guess thats what the "T3 Super-60" means?
10 Re: T28 ball bearing turbo? on 22nd July 2015, 8:07 am
Yeah was gonna say I can confirm 100% the stock t28 isn't a roll bearing turbo, still we have an easier time than the skyline boys with their ceramic turbos they like to shit themselves on a regular basis haha!
11 Re: T28 ball bearing turbo? on 22nd July 2015, 6:47 pm
I think that t28r it's standard s15 silvia turbo and this is roller bearing job and apparently it's not bad turbo
12 Re: T28 ball bearing turbo? on 22nd July 2015, 9:45 pm
lenzo
No t Series turbo is ball bearing it's only the gt series that are ball bearing the t series are Journal bearing only
13 Re: T28 ball bearing turbo? on 22nd July 2015, 10:59 pm
Hmm i thought that r on the end was for ball bearings ah well you learn something every day Smile
14 Re: T28 ball bearing turbo? on 22nd July 2015, 11:04 pm
lenzo
You can by the conversion kit for a t28 will become a ball bearing turbo
15 Re: T28 ball bearing turbo? on 23rd July 2015, 3:27 pm
@lenzo wrote:No t Series turbo is ball bearing it's only the gt series that are ball bearing the t series are Journal bearing only
the s14 t28 is a ball bearing turbo?
16 Re: T28 ball bearing turbo? on 23rd July 2015, 3:29 pm
As far as know no...Only s15 is ball bearing
17 Re: T28 ball bearing turbo? on 23rd July 2015, 6:53 pm
lenzo
The s15 come standard with a gt28r
18 Re: T28 ball bearing turbo? on 23rd July 2015, 6:56 pm
lenzo
Not a T28 no T28 is a ball bearing turbo only the GT series
19 Re: T28 ball bearing turbo? on 23rd July 2015, 7:02 pm
http://www.turbobygarrett.com/turbobygarrett/garrett_nomenclature
http://www.turbodynamics.co.uk/technical/technical-info/garrett-turbo-tech/garrett-gt-vs-t-series/
