Gtir Motorsport club » Tech room » Help and Advice » oil light
oil light
1 oil light on Mon Aug 03, 2015 7:30 am
My oil light flickered on and off just. I wasnt pushing it.
Car was upto temperature and oil pressure is fine.
The light only came on faint twice.
I was going around an island at the time.
I checked the oil level yesterday and thats fine.
Could it be a loose wire maybe?
Which one is the oil light sensor?
2 Re: oil light on Mon Aug 03, 2015 9:08 am
The one sensor runs the pressure gauge and dash light. Id start by undoing the plug at the sensor and giving it a clean.
3 Re: oil light on Mon Aug 03, 2015 9:16 am
Okay thanks.
Will have a look at it tomorrow.
4 Re: oil light on Mon Aug 03, 2015 9:35 am
Where the sensor located then ???
5 Re: oil light on Mon Aug 03, 2015 9:57 am
right next to the oil filter ...
I changed mine as gauge accuracy was suspect. fitted new centre guages & made a y style adaptor to fit standard pressure switch fitting & had new gauge sensor in one outlet & in other used a 0.7-0.8bar mitsubishi oil pressure switch wired in for the dash oil light.
6 Re: oil light on Wed Aug 05, 2015 6:39 am
Just got myself under the car to check this out.
The sensor wire was dangling down and resting on the driveshaft.
One of the wires has a cut in it so im guessing it was earthing out on the driveshaft?
I have cable tied it up out the way anyways so i will see the next time i go out.
I took the plug off and gave it a spray with the electrical cleaner while i was there.
