Gtir Motorsport club » General Discusion » Gtir related Discussion » Wheel bearing
Wheel bearing
1 Wheel bearing on 9th August 2015, 8:25 pm
Would anyone happen to have an R wheel bearing laying around and be able to measure the OD, ID and height for me please? Smile
2 Re: Wheel bearing on 9th August 2015, 8:35 pm
Just measured the one in my kitchen Laughing
OD = 74mm
ID = 38mm
height = 36mm
Gaz
3 Re: Wheel bearing on 9th August 2015, 8:41 pm
That was convenient Smile Thanks heaps mate!
4 Re: Wheel bearing on 9th August 2015, 8:52 pm
Everybody in the uk keeps wheelbearings in the kitchen its just you wierd aussies that leave them in the garage or such like .... bloody wierdos Laughing Laughing Laughing
5 Re: Wheel bearing on 9th August 2015, 9:24 pm
Haha Laughing I'd build an engine in the kitchen if I could Laughing
6 Re: Wheel bearing on 9th August 2015, 10:10 pm
I actually have built an rs turbo engine in my old kitchen few years back now lol ...
7 Re: Wheel bearing on 9th August 2015, 10:45 pm
You could cook dinner and build an engine at the same time Laughing
8 Re: Wheel bearing on 9th August 2015, 10:49 pm
Lol to be fair everybit of the engine had been chemicaly cleaned so only oil that went near it was assembly lube .... until it went in the car of course ...
9 Re: Wheel bearing on 10th August 2015, 8:13 am
I took it one stage further at my last house, the wife had a 1.0ltr Yaris compression had gone on two of the cylinders so as I knew them engines inside out decided to strip it and recondition. Was saving for the wedding so didn't want to buy a new car at the time.
Unknowns to me over the years she had run out of oil on several occasions, so once stripping the engine down I was faced with oil burnt onto the block and head. So my ingenious solution???? Yep as the engines small put it through the dishwasher Laughing came out like new
Thought I had a pic after the cycle.
Worked a treat after the rebuild, sold it 2 years later and it's still going strong to this day!
10 Re: Wheel bearing on 10th August 2015, 9:52 am
^ what amazes me mr burrows is you have car parts in kitchen, an engine in the washing machine, you take your wife to scap yards to steals bulbs & you actually did get married & assume you still are today :-O
I will take points off her for running out of oil in the yaris, 50 lashes with a oil dipstick for that offence ...
11 Re: Wheel bearing on 10th August 2015, 8:03 pm
Exactly what a washing machine should be used for Laughing
12 Re: Wheel bearing on 12th August 2015, 10:06 pm
I did that at my old house. Put rocker cover in the dishwasher problem was rocker came out fine but all the plastic coating on the washer frame was grey with oil, took me far longer to clean the framework than it would have the rocker cover
13 Re: Wheel bearing on 12th August 2015, 10:11 pm
Lol sometimes shit happens atleast the idea was there Wink
14 Re: Wheel bearing on 9th October 2015, 7:18 am
Whats the easiest way to remove the snap ring when removing the wheel bearing? Fookin pain.
15 Re: Wheel bearing on 9th October 2015, 10:00 am
Here ya go
http://www.gtirworkshopmanual.com/default.aspx?v=1683
16 Re: Wheel bearing on 9th October 2015, 9:09 pm
Thanks Gaz, I saw that but still cant figure it. Ill have another look, Ive got 4 different sets of snap ring pliers and they didnt work.
17 Re: Wheel bearing on 9th October 2015, 9:22 pm
internal clip pliers will work, sometimes you need grind tips a bit to make them fit slots well, sometimes can help tap them with a suitable flat head screwdriver to get them moving free, can be handy have a wire pick & thin screwdrivers on hand to keep clip partly out & manipulate it out of groove if being stubborn ...
18 Re: Wheel bearing on 9th October 2015, 9:39 pm
Thanks B, Ill have another look today, it cant be that hard.
19 Re: Wheel bearing on 9th October 2015, 10:16 pm
I normally just manipulate them out with a flat screwdriver alot of the time you can get them to budge if you tap them about with a screwdriver and hammer get down the side of it then twist the screwdriver then pull it up then do it to the otherside then your get you pliers on in the groves ...
20 Re: Wheel bearing on 10th October 2015, 3:04 am
I try again today, the bastards are coming out one way or another Laughing
21 Re: Wheel bearing on 10th October 2015, 7:27 am
Got them out thanks lads, I was trying to get them on the ends originally, that's why I had nothing to leverage off and it kept slipping.
22 Re: Wheel bearing on 10th October 2015, 11:13 pm
What did you use and how did you get them out?
Would be useful for future if member have to do same.
23 Re: Wheel bearing on 11th October 2015, 12:11 am
I used the smaller flat blade to get the ring out of the seat and then wedged the bigger flat blade behind it, then gently moved the screwdriver around the ring to get it out.
24 Re: Wheel bearing on 11th October 2015, 2:37 am
Yep, was going to suggested something along those lines but thought you may have tried it, and you did.
Putting new ones in, bed one end in the recess and put the flat screwdriver in the knotched out slot, put pressure on the ring to get it too slide down the blade and it should just pop in.
25 Re: Wheel bearing on 11th October 2015, 10:15 am
See screwdriver wins sometimes just the basic tool is all you need ....
