Gtir Motorsport club » Tech room » Help and Advice » Gear box sensor
Gear box sensor
1 Gear box sensor on 21st August 2015, 6:07 pm
Rscozzy
Hi all wanting to no what the sensor called at the bottom of gearbox near side is leaking where can I get 1 cheers
2 Re: Gear box sensor on 21st August 2015, 7:59 pm
Im trying to think what sensor it is as you got speed sensor on top plus i believe the reverse switch is also on top ....
3 Re: Gear box sensor on 21st August 2015, 8:27 pm
Reserve switch is underneath the left driveshaft kinda.
4 Re: Gear box sensor on 21st August 2015, 8:45 pm
Rscozzy
Its bolted on with 1 10mm bolt
5 Re: Gear box sensor on 21st August 2015, 8:54 pm
Rscozzy
Part number on gtir manuals is 30025m
6 Re: Gear box sensor on 22nd August 2015, 12:55 pm
I would say as woody it reverse switch.
Also think you quoted part# wrong ! should be 32005m (3200517E01 or 3200517E11) !?
7 Re: Gear box sensor on 22nd August 2015, 2:40 pm
Rscozzy
Yeh put 3 in wrong place cheers
