Gtir Motorsport club » General Discusion » Gtir related Discussion » engine not starting
engine not starting
26 Re: engine not starting on 23rd August 2015, 1:35 pm
joetheeskimo
@Stu wrote:What did you use to put that vacuum into the ic pipe from the turbo?
Im struggling to find something so i can take another feed off mine to the wastegate.
Sorry what vacuum are you talking about. I don't have any vacuum lines going to intercooler. The waste gate is connected directly to the inlet plenum.
27 Re: engine not starting on 23rd August 2015, 1:36 pm
joetheeskimo
@Petelesta wrote:What rectified the problem then joe ? It's useful to know for future reference Smile
I belive the fuel was old. It's been sat in the tank for 6 months. Once it has sprayed enough the pipes had cleaned out and it started
28 Re: engine not starting on 23rd August 2015, 3:47 pm
29 Re: engine not starting on 23rd August 2015, 4:16 pm
joetheeskimo
That pipe is just plugged, it came on the intercooler pipe when i bought it from Bob. Its just blanked off.
Got an issue with the engine its leaking fluid from the waterpump area, its not from the bolt but from either a hairline crack or the seal. What should i do about this, any easy fixes for it.
its even pouring out fluid with the engine off.
30 Re: engine not starting on 23rd August 2015, 4:48 pm
new water pump.
get an ADL blueprint one ( ADN19141 ) as not too expensive (£40 from friendly autofactors) & comes with a gasket which makes fitting with engine in car far far easier :-S over mucking about with gasket sealant, just use supplied gasket smeared very lightly with grease .
31 Re: engine not starting on 23rd August 2015, 5:02 pm
On the water pump theres a small hole in them that pisses water out if the engine is left standing for a long time. I have seen it a few times.
I guess theres a seal inside that drys out???
32 Re: engine not starting on 23rd August 2015, 5:36 pm
joetheeskimo
@Stu wrote:On the water pump theres a small hole in them that pisses water out if the engine is left standing for a long time. I have seen it a few times.
How do I get around this. Do I need to replace it.
33 Re: engine not starting on 23rd August 2015, 5:55 pm
Thats what i had to do on one of my other gtir builds yes.
34 Re: engine not starting on 23rd August 2015, 6:05 pm
I had the same problem once I had drained the system a left for a short time, I order a new pump but it never leaked again
35 Re: engine not starting on 23rd August 2015, 6:30 pm
joetheeskimo
@buckym120 wrote:I had the same problem once I had drained the system a left for a short time, I order a new pump but it never leaked again
Is it difficult to change, i know its just a few bolts so that wont be a problem but access to it will be the most annoying. Wish i had changed it when it was out of the car.
Never mind, always make things more difficult for my self.
36 Re: engine not starting on 23rd August 2015, 6:41 pm
Jack up or down the engine for better access ....
37 Re: engine not starting on 23rd August 2015, 7:32 pm
joetheeskimo
would a GTI water pump fit a GTIR.
Thanks
38 Re: engine not starting on 23rd August 2015, 8:43 pm
^ no it won't joe.
Just pick up a new ADL ADN19141 at best price you can get. don't mess with used pumps as even good used pump left shelved go bad & are a risk. new is not expensive . Once you fitted one you will realize half reason you don't want risk doing it again over 10-£20, other half of the reason is you don't want possible hassle of a leaky pump causing heating issues & damaging engine ...
39 Re: engine not starting on 23rd August 2015, 8:54 pm
I wouldnt even skimp on a pattern part, important part of the car why risk it, just to save 30 quid.
Can imagine it being a right pain insitu but should be do able once the engine mount and maybe power steering pipes are out the way
40 Re: engine not starting on 23rd August 2015, 8:57 pm
^ ADL pump is same quality jap made pump you get from nissan, just a different box, better price & generally quicker sourced, plus you get a gasket which I much prefer for fitting when engine in car ...
