Gtir Motorsport club » Tech room » Help and Advice » Lagging in power
Lagging in power
1 Lagging in power on 23rd August 2015, 10:00 am
Ryds
Hi all
Got my pulsar at last. It's been sat for about 2 years but on idle sounds good no knocking or smoke. Went out for a short drive to see how she is and she lags as if she can't breath. Going to give a full service has anyone got any ideas on what might be the issue.
2 Re: Lagging in power on 23rd August 2015, 10:33 am
pulsar23
What air filter you using? Obviously check breather pipes etc... General service can work miracles!!
3 Re: Lagging in power on 23rd August 2015, 10:57 am
Afm might need a clean.
I take it after 2 years of standing you have filled the fuel up. Old fuel will make the car run shite.
4 Re: Lagging in power on 23rd August 2015, 11:03 am
Ryds
Soon as I do the service and add new fuel I'll let you know how she is running thanks.
5 Re: Lagging in power on 23rd August 2015, 2:19 pm
Personslly i can not belive you would be testing a car out if it's sat for two year without fully servicing and checking every last bit of it if it's sat. Change all fluids ,plugs check pipes two year clean afm and check dizzy etc lots to do
6 Re: Lagging in power on 23rd August 2015, 4:11 pm
Ryds
I know what your saying Johnny and I will be doing all that before hitting the road. Thanks for the advice.
7 Re: Lagging in power on 23rd August 2015, 8:20 pm
Re read that sounds harsh never ment it to come across like that just mean sometimes you leave them 5 mins and they need checked just don't want something simple costing you your engine
8 Re: Lagging in power on 23rd August 2015, 8:45 pm
Ryds
Thanks I will do my best to get her right as it will be pride and joy now owning one again. I'll keep you posted on here on my progress and asking if I need any other help. Thanks again.
9 Re: Lagging in power on 26th October 2015, 8:02 pm
Right so I've had look on it too got rid of misfire on boost (dizzy) sorted out vacc piping etc, but car is still low on compression on cyl no 4
no1 to 3 150psi no4 75 psi we've put some penetrator oil left it for couple of days and no change. Put some oil down the bore it rise comp to 125 psi warmed car up (stopped smoking etc) and comp back to 75 psi. There is no smoke or knock etc from top or bottom car takes that extra turn to start drives ok when cold not so ok when warmed up. Another thing which I've noticed oil temp is going up very quickly after 1mile it's around 90 deg and there is rust in coolant.
So have you guys got any suggestions before I'll take head off??
10 Re: Lagging in power on 26th October 2015, 8:22 pm
