Gtir Motorsport club » General Discusion » Gtir related Discussion » Rear Hub long Bolt
Rear Hub long Bolt
1 Rear Hub long Bolt on 29th August 2015, 1:15 pm
Hi,
Just incase anyone is interested, the long bolt thats a arse to remove from rear hub, checked with Nissan today to how much a new one is:
Bolt 55166-60Y00 Alt/No 55166-60Y0A - £10.12 ea Sec: 431
And the bolt for front lower arm, the one that goes through lower arm bush and chassis leg:
Bolt 54368-50Y10 Alt/No 54368-50Y11 - £7.52 ea Sec: 401
Gaz
2 Re: Rear Hub long Bolt on 29th August 2015, 5:22 pm
I had to cut mine out a few years back what a little fucker it was
3 Re: Rear Hub long Bolt on 29th August 2015, 7:09 pm
Mine came out, but was a royal pain in the ass!
4 Re: Rear Hub long Bolt on 1st September 2015, 6:09 pm
FPSChris
FPSChris
Took to drinking after attempting it. lol
What an utter c**t of a bolt!
Do they normally bend then?
Both OS and NS on mine were gone.
5 Re: Rear Hub long Bolt on 1st September 2015, 6:43 pm
Dont think mine was bent was just seized solid inside the hub
6 Re: Rear Hub long Bolt on 1st September 2015, 8:20 pm
Get same problem on loads of lateral link hub bolts on many cars, had same issue on my mazda 323B6T & that was total f00ker & cut both ends & hub was soaked in penetrating oil for several days then left in a press over weekend before budged :-S
subaru have same issue too lol
7 Re: Rear Hub long Bolt on 1st September 2015, 8:30 pm
Nice to know we are not the only poor fookers that suffer ....Wink
8 Re: Rear Hub long Bolt on 1st September 2015, 8:33 pm
Blimey Mr B, think I got off lightly really! think I used a 1.5m breaker bar and just kept moderate pressure applyied and slowly worked it. Mate sand blasted the bolts at work, I reapplied the zinc finish looks like new again, but for the sake of a few quid might buy new..
9 Re: Rear Hub long Bolt on 1st September 2015, 8:57 pm
My mazda would not budge with heat, airgun, breaker bars etc, was seized super solid in all fittings of bushes & hub, both sides same too :-( mazda bolts 2.5x price of nissan & with lateral bushes worked out an expensive for what it was.
Done a few subaru with same sort of issues. we not alone, bit like rear arches as the classic impreza has worse arch rear quarter issues than the R lol
10 Re: Rear Hub long Bolt on 1st September 2015, 9:04 pm
What causes the rot problems on the R? After replacing arches and other panels, ive seam sealed everything, especially round the fuel filler hole, looked like the two skins had started to seperate, prob main reason why my arch rotted..
11 Re: Rear Hub long Bolt on 1st September 2015, 9:05 pm
^ before anyone says water, i know that bit Laughing
12 Re: Rear Hub long Bolt on 1st September 2015, 9:20 pm
Rain lol salt is a big contributer over here
13 Re: Rear Hub long Bolt on 1st September 2015, 9:25 pm
Its the rust fairy ...... i think as johnny said its rain and mud and crap off the road sticks up inside the arch creates damp and the aids it to start the process...
14 Re: Rear Hub long Bolt on 1st September 2015, 9:29 pm
Is it a design flaw? my arch went directly below fuel filler, when inspecting the fuel filler bit and seeing the two panels seperating water was obviously getting in and becoming trapped inside the arch..
15 Re: Rear Hub long Bolt on 27th March 2016, 8:51 pm
Just took mine out. Came out fairly easy with breaker bar and a bit of wd40 so guess I got lucky
16 Re: Rear Hub long Bolt on 27th March 2016, 9:09 pm
Good to hear, you are a lucky man Laughing
17 Re: Rear Hub long Bolt on 5th October 2017, 8:13 am
For anyone interested I tried to get these from nissan awhile ago and couldn't get them, they must be restocked now.
18 Re: Rear Hub long Bolt on 5th October 2017, 2:46 pm
did i not send you two Chris?
19 Re: Rear Hub long Bolt on 5th October 2017, 8:15 pm
Yeah you did bob they are on my car Smile but got these when I ordered other bolts for the rear, gotta hoard things while they are available Laughing
20 Re: Rear Hub long Bolt on 6th October 2017, 11:13 pm
typeritr
typeritr
I took mine out the other day and it was easy??? covered it in WD40 the day before. Went back the following day, removed the nut, hit the bolt with a mallet and it came out, then got a ratchet extension and put it through the hub so I could continue hitting it out. Maybe i was lucky!
21 Re: Rear Hub long Bolt on 7th October 2017, 4:14 am
Some are lucky and some aren't, just depends how they were put together and how long they been in there for I guess
22 Re: Rear Hub long Bolt on 7th October 2017, 6:11 am
Totally what Woody says
23 Re: Rear Hub long Bolt on 7th October 2017, 12:30 pm
if been in there 20+ years unlikely come out easy and even more so in uk climate/salt. any coming out easy either been out at least once before or spent a lot of it's life in dry climate/storage .
24 Re: Rear Hub long Bolt on 7th October 2017, 12:55 pm
typeritr
typeritr
I reckon i may have been lucky so, my car was never driven in the UK. I will start a thread on my car as I am rebuilding it, that's why I was taking it out.
25 Re: Rear Hub long Bolt on 7th October 2017, 5:16 pm
Look forward to the thread
