Gtir Motorsport club » General Discusion » Gtir related Discussion » Fuel and brake Lines
1 Fuel and brake Lines on 1st September 2015, 9:35 pm
Im getting to the point of ordering new lines but before I do need to check there the right sizes:
Fuel - http://www.ebay.co.uk/itm/200645036388?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Brake - http://www.ebay.co.uk/itm/3-16-X-25-FT-CUPRO-NICKEL-KUNIFER-BRAKE-FUEL-PIPE-TUBING-ROLL-25ft-BS-EN12449-/121746661402?hash=item1c58aaa01a
Would it be benificial to increase the dimeter of the fuel lines?
Gaz
2 Re: Fuel and brake Lines on 1st September 2015, 9:54 pm
if your changing fuel pipes would it not be better to go to something like
http://www.ebay.co.uk/itm/Stainless-Steel-Braided-TEFLON-PTFE-Fuel-Pipe-Hose-Car-Van-Petrol-ALL-SIZES-/271529340140?var=&hash=item3f3868ecec
not recommending those in particular its just the first i found on ebay
3 Re: Fuel and brake Lines on 1st September 2015, 10:06 pm
I used braided hose for all my fuel lines and it was so much easier than messing with hard lines. Have you used hard lines before? You'll need proper bending and flaring tools. I tried to replace the steel brake lines on my old pulsar and it looked like rubbish and I couldn't get the bend really neat.
4 Re: Fuel and brake Lines on 1st September 2015, 10:11 pm
Can that type of pipe be used under the car?  Im using it in the engine bay, ditching the cheap blue fuel hose I got, looked good but it leaked through the side of the pipe Shocked
Got the flaring tools etc, wanted to keep it stock looking underneath tbh not sure why Laughing
5 Re: Fuel and brake Lines on 1st September 2015, 11:29 pm
I would run the underside in copper if I were you and same with bulkhead pipes, at least they won't rust
6 Re: Fuel and brake Lines on 2nd September 2015, 2:06 pm
you can use teflon stainless braided hose under care if rooted well & secured well, allows neat & easy install in refined space/bends.
It better than most rubber hose as hard find good fuel grade 30r9 or higher & many rubber fuel hoses from motorfactors etc don't even have grade markings on the hose :-/
7 Re: Fuel and brake Lines on 2nd September 2015, 4:10 pm
Take the lines through the car
8 Re: Fuel and brake Lines on 2nd September 2015, 4:26 pm
^ you could with teflon, I would keep them outside & just route secure & shield much same as original layout.
9 Re: Fuel and brake Lines on 2nd September 2015, 4:35 pm
Braided is ok but rubs and braided when they start to breakdown you can not see them failing
10 Re: Fuel and brake Lines on 2nd September 2015, 4:52 pm
^ Teflon/ptfe likely outlast the car if fitted well.
11 Re: Fuel and brake Lines on 2nd September 2015, 8:14 pm
Yeah the common braided hose which is 100 series can't be run through the car. It's fine under the car, just make sure you use plenty of clamps to prevent the hose from sagging or rubbing on things.
12 Re: Fuel and brake Lines on 11th September 2015, 1:40 am
grim_d
How are people swaging/beading the 1/4" fuel lines for rubber hose connection? Have a cracking flaring tool for the brake lines but not figured out what to do for the fuel lines.
13 Re: Fuel and brake Lines on 11th September 2015, 10:29 pm
I'm trying to figure this out as well, gotta be a tool available?
14 Re: Fuel and brake Lines on 11th September 2015, 10:37 pm
grim_d
There is but they are not cheap.
15 Re: Fuel and brake Lines on 13th September 2015, 7:39 pm
Whats the tool called mate?
16 Re: Fuel and brake Lines on 15th September 2015, 6:42 am
grim_d
A pipe beader, but one that is small enough for 1/4 pipe.
earls does a smashing little tool but 3/8 is the smallest unfortunately http://www.earls.co.uk/earls/accessories/tools/beadingtools.html
Only ones I've found that will do small enough are the parker style ones, light aircraft tooling.
http://www.grahamtool.com/smalltubebeadingtool.aspx
http://aircraftproducts.wicksaircraft.com/item/tubing-aircraft-tools/tube-beading-kit/ap145?
17 Re: Fuel and brake Lines on 15th September 2015, 7:06 am
18 Re: Fuel and brake Lines on 15th September 2015, 7:08 am
Saw this ^^^^ but as you say no 1/4 3/8 is the smallest ....
19 Re: Fuel and brake Lines on 15th September 2015, 7:09 am
grim_d
Same link in my post old chap. Very Happy
20 Re: Fuel and brake Lines on 15th September 2015, 7:34 am
Something like this?
http://m.supercheapauto.com.au/Product/SCA-Tube-Flaring-Kit/214269
21 Re: Fuel and brake Lines on 15th September 2015, 7:42 am
grim_d
That's a flaring tool rather than a beading tool however a flare on the end would serve much the same purpose, just a bit harder to push the hose on, it's what I'm planning on using in the absence of a beading tool.
That particular tool though only makes a mess of functional flares for brake pipes, someone left one of those in my workshop, I wouldn't put it anywhere near a brake line.
22 Re: Fuel and brake Lines on 15th September 2015, 7:54 am
Yeah fairly cheap compared to others so wouldn't expect an awesome job. Might get the job done though
23 Re: Fuel and brake Lines on 18th September 2015, 4:49 pm
Can anybody recommend a decent but not braking the bank flaring tool?
Ive got one of them cheap and nasty tools but after reading reviews not sure I wat to use it now! I will be using Cupro Nickel (Kunifer) fuel and brake pipe.
24 Re: Fuel and brake Lines on 18th September 2015, 5:13 pm
grim_d
http://pages.ebay.com/link/?nav=item.view&id=181063197795&alt=web
Makes perfect flares every time and doesn't Marr the pipes.
25 Re: Fuel and brake Lines on 18th September 2015, 5:21 pm
Nice one cheers pal Cool
