Gtir Motorsport club » Tech room » Help and Advice » Squeeling sound
Squeeling sound
1 Squeeling sound on 4th September 2015, 6:29 am
colin22
Hello, my car has a squeeling sound coming from the front passenger side that comes up when the car goes 60km/hr or higher. When the car is slower than 60km/hr the noise isn't there. If I step on the brakes, it doesn't make the sound go away. It's directly related to how fast the car is going. I've recently changed new front brake pads and rotors and the noise is still there and I've tried wobbling the wheel to see if it's wheel bearing but there doesn't seem to be any play. Does anyone know what may be causing this?
2 Re: Squeeling sound on 4th September 2015, 7:31 am
You still got the brake dust shields on yours ? It's not that bent when you done brakes catching ?
Just read this properly it was there before hand.
3 Re: Squeeling sound on 6th September 2015, 5:06 am
colin22
The dust shield is still there. Ive tried bending it back but the sounds still there.
4 Re: Squeeling sound on 6th September 2015, 6:45 am
And it's not bearing early stages sqweeling but just not lots of play on it yet ?  How loud is it and you say speed related passenger side ? And boots ok on inner shaft
Dose it do it if you move steering or dip clutch and put it into neutral
5 Re: Squeeling sound on 6th September 2015, 7:41 am
Thermal
I had a loose centre hub nut loose (not on a Nissan though) that gave a squeal when driving, quick and easy check to do.
6 Re: Squeeling sound on 7th September 2015, 7:38 pm
pulsar23
Have you jacked the front up and spun wheels to see if you can he it faintly?
7 Re: Squeeling sound on 7th September 2015, 7:40 pm
colin22
I can only hear it when going 60km/hr or more.
