Gtir Motorsport club » Tech room » Help and Advice » fuel filler neck and pipe
1 fuel filler neck and pipe on 8th September 2015, 9:12 pm
FPSChris
Which one do I need?
My pipe needs replacing, don't want to replace with soft pipe. Needs to be as standard as possible.
Three on here - http://www.carz2.co.uk/nissan-sunny-n14-sedhb-91-95-16450-c.asp
Which one?
2 Re: fuel filler neck and pipe on 2nd October 2015, 2:53 pm
FPSChris
Anyone know which part I need?
Needs swapping out asap.
3 Re: fuel filler neck and pipe on 2nd October 2015, 6:28 pm
One in link below is little cheaper & model list includes gtir so should be able return if it was wrong .
Nissan part number is > 1722154C00
BLIC part number is > 6906-00-1628529P
http://www.bestpartstore.co.uk/7180861
looking at the nissan part number it appears specific for 4wd nissans.
never done one so I don't know if this part is close enough to be usable ...
4 Re: fuel filler neck and pipe on 4th October 2015, 6:12 am
@Mr B wrote:One in link below is little cheaper & model list includes gtir so should be able return if it was wrong .
It is specific.
The GTI-R, being 4WD has a fuel tank that straddles the tailshaft, where as the 3door Sunny has a flat tank.
The mounting points for the fuel filler neck and the pump are in different locations.
5 Re: fuel filler neck and pipe on 4th October 2015, 11:09 am
It maybe close enough to be adaptable but hard say without trying & part not that cheap to warrant much fuss, looks like a new oem one or good used is easy way forward.
6 Re: fuel filler neck and pipe on 4th October 2015, 12:09 pm
Ive never payed that much attention to the design of it .... if you had posted this last month i had one off the shell you could of had if you had paid postage .. Rolling Eyes
7 Re: fuel filler neck and pipe on 16th October 2015, 4:43 pm
FPSChris
Thank you, I'll grab 6 week parts from Japan.
@splmum wrote:
It is specific.
Thanks, going for genuine Nis.
@nomad wrote:Ive never payed that much attention to the design of it .... if you had posted this last month i had one off the shell  you could of had if you had paid postage .. Rolling Eyes
Rolling Eyes Rolling Eyes Rolling Eyes Rolling Eyes Rolling Eyes
I've only just had time to finish off the little bits, I don't think mines poor but as I've replaced everything else I didn't see the point in leaving it.
