Gtir Motorsport club » General Discusion » Gtir related Discussion » Power flex engine mount
1 Power flex engine mount on 10th September 2015, 7:17 pm
Just got the power flex upper engine mount, with the old knackered mount do I cut out the old rubber or does it come out with metal inner ring if that makes sense? If any one has fitted these before they will know what I mean. Cheers
2 Re: Power flex engine mount on 10th September 2015, 10:41 pm
Break the middle out of the rubber then get a chisel and knock the outer ring towards the centre so it breaks away from the main housing.
Clean the surface for the new bush, lube it with grease and refit
3 Re: Power flex engine mount on 11th September 2015, 5:29 am
Cheers Bob thumbsup
