Gtir Motorsport club » Tool section » self brake bleeding kits
1 self brake bleeding kits on 15th September 2015, 2:11 am
Anyone used these self brake bleeding kits before? Are they any good, I've seen a different types? I've always had someone to help me but thought I'd get one this time.
2 Re: self brake bleeding kits on 15th September 2015, 6:58 am
Wich ones do you mean woody .... ive got a dual brake bleeding kit .... it has a rubber nipple with a ball bearing in the end wich stops the fluid sucking back up ???
3 Re: self brake bleeding kits on 15th September 2015, 7:17 am
These are the different sorts ranging from $15 up to $75 for the red one. Guess I don't want to pay a lot but still want it to work well etc.
4 Re: self brake bleeding kits on 15th September 2015, 9:28 am
I have used the top one pictured. You connect it to a valve on a wheel and the air pressure pushes the fluid threw for you. Very handy when you are alone and need to bleed your brakes Smile
5 Re: self brake bleeding kits on 15th September 2015, 10:18 am
Yeah I used something similar to bleep my clutch slave
http://www.halfords.com/workshop-tools/tools/hand-tools/europat-vizibleed-brake-and-clutch-bleeding-kit
Worked well, used another kit that connected to your tyre for pressure and the fucker blew off and sprayed me in the face with clutch fluid I soon smashed that up and threw it in the bin.
Sometimes simple is better tongue
6 Re: self brake bleeding kits on 15th September 2015, 11:02 am
@shroom wrote:Yeah I used something similar to bleep my clutch slave
I didnt put the fluid in the container. I used it as an air compressor cylinder and just used the air to push the fluid out of the reservoir. Just made sure it didnt run dry...
7 Re: self brake bleeding kits on 15th September 2015, 11:24 am
pressure or suction systems can be good for problem systems with abs & airlocks.
for simple bleeding I use a homemade one man bleeder from 12" clear hose with bit of old brake line as a joiner to a bit of decent black rubber hose that tight grippy fit on the nipple & use a wire spring clip to save any mishaps of it popping off. On other end of the clear hose I have a alloy one way valve. Makes minor bleeding a no hassle job, still tend use 2 people as it quicker & you can see exactly how it bleeding & complete a front & rear quickly.
8 Re: self brake bleeding kits on 15th September 2015, 11:36 am
Whytie
I simply put a vac hose around nipple and the other end in a jar with some brake fluid and pump away job done, if the end is submerged in fluid it won't let air back in.
9 Re: self brake bleeding kits on 15th September 2015, 12:07 pm
@Whytie wrote:I simply put a vac hose around nipple and the other end in a jar with some brake fluid and pump away job done, if the end is submerged in fluid it won't let air back in.
This is how i blead my sons moped brakes.
10 Re: self brake bleeding kits on 15th September 2015, 12:56 pm
Basically same as what I do but with a one way valve as you get less reverse flow between pedal strokes & with a valve it helps create flow cycle when lot of air in the system.
11 Re: self brake bleeding kits on 15th September 2015, 8:07 pm
Thanks for the comments guys. Sounds the simplest method is the best way to go about it Smile
12 Re: self brake bleeding kits on 16th September 2015, 7:45 pm
Supernova
Be careful I have an ezibleed on of these http://www.amazon.co.uk/Gunson-G4062F-G4062-Eezibleed-Kit/dp/B001KTFIWA
It works fine for my fabia but it didn't have the right size cap for the pulsar so I had to use a couple of blocks of wood hillbilly style when I had to bleed mine.
13 Re: self brake bleeding kits on 16th September 2015, 9:22 pm
Yeah I tried that and it didnt work and blew off and got me all in the face lol
14 Re: self brake bleeding kits on 10th April 2016, 6:10 am
I used this one today. Easy as and worked really well
After having all the calipers removed I brought 3 bottles of fluid because I thought there would be no fluid left in the lines. Only end up using 1 full bottle.
15 Re: self brake bleeding kits on 10th April 2016, 10:14 am
Im looking at investing in one of these:
http://www.ebay.co.uk/itm/Brake-and-Clutch-Fluid-Bleeding-System-Bleed-UA-Kit-Sealey-VS820-Bleeder-Tool-/401093090111?hash=item5d6302db3f:g:6l4AAOSwu1VW8ZR7
Dont know how effective it will be on a completely dry system though.... Plus her golf and my tranny need doing so probably might be worth it..
16 Re: self brake bleeding kits on 10th April 2016, 5:31 pm
Just make sure the adapter actaully screws or connects to the pulsar resivour as they dont always
17 Re: self brake bleeding kits on 10th April 2016, 7:49 pm
^good point! Will go the old way with a tube and jar Very Happy
18 Re: self brake bleeding kits on 10th April 2016, 8:26 pm
The pulsar uses a push on type on the cheaper easy bleeds none of the screw ones fit on the gunson ones or is it the fact some of mine were missing. I bought one of these but yet to use it
19 Re: self brake bleeding kits on 10th April 2016, 8:27 pm
https://www.machinemart.co.uk/p/clarke-cht637-air-operated-clutch-brake-blee/
20 Re: self brake bleeding kits on 10th April 2016, 9:14 pm
How much fluid should a dry brake system take?
21 Re: self brake bleeding kits on 10th April 2016, 10:16 pm
I'm looking for a decent one myself.
I have this one as my current but it's not very good has a crap seal and the handle comes off but it's a rebrand of a rebrand of a rebrand
http://pages.ebay.com/link/?nav=item.view&id=180820654002&alt=web
22 Re: self brake bleeding kits on 1st May 2016, 2:48 pm
I have used a few types in the past but I've just bought the one way ball bearing type off eBay. Very cheap and it worked perfectly so I'll be sticking with that. And only one person needed to operate just keep an eye on your fluid level obviously
