Gtir Motorsport club » General Discusion » Gtir related Discussion » oil pump
oil pump
1 oil pump on 22nd September 2015, 6:01 pm
luke s
I spoke to a friend at Nissan he said they do a oil pump refurb kit has any one used this kit or would it be best to use complete new pump ?
2 Re: oil pump on 22nd September 2015, 6:18 pm
GTIR James
Yes a rotor kit can be had from Nissan. You will need to strip yours to see if the oil pump housing is marked if not a rotor kit can be used but a complete new pump is better.
3 Re: oil pump on 22nd September 2015, 7:10 pm
luke s
Ok brilliant thank you
4 Re: oil pump on 22nd September 2015, 7:26 pm
Used to be able to get a bigger rotor  kit from somewhere but think there discontinued now
5 Re: oil pump on 22nd September 2015, 8:00 pm
luke s
Iv been told the standard and after market ones are diffrent?
6 Re: oil pump on 20th October 2015, 9:19 pm
luke s
Hit a snag spoke to Nissan but there not able to sell a rebuild kit, does anyone know where I can get a rebuild kit?
7 Re: oil pump on 20th October 2015, 9:45 pm
Don't waste your money just buy a new pump because if any fragments of metal have gone through it I guarantee you it will have scored the casing.
Just not worth the gamble to save a few quid
                                GTI-R-US.CO.UK
                                            'In association with'
                                          'Services provided'
8 Re: oil pump on 20th October 2015, 9:47 pm
luke s
True might as well get one orderd at least it's all new then
9 Re: oil pump on 21st October 2015, 6:17 am
As above I know things cost but is it worth it I had a forged lump and someone rebuilt it few thousand mile later. Oil pressure droped slightly checked everything without stripping engine next thing 60 mph bang turns out oil pump was inspected or rebuilt and it parted inside as someone did not lock tight the screws apart from that engine was as described when bought and got a good few thousand miles before it gave up. Shop around as prices vary and importing is a option just calculate import duty on it and post your findings or Nissan price please
10 Re: oil pump on 21st October 2015, 6:43 am
luke s
True points Johnny, I seen someone post that a new pump can be brought from USA for £175 deliverd but can't find who from, nissen would be around £300
11 Re: oil pump on 21st October 2015, 12:31 pm
http://www.frsport.com/Nissan-13500-54C00-Pulsar-GTi-R-GTiR-SR20DET-Front-Timing-Cover-Oil-Pump-Assembly_p_1798.html
about 118gbp base price.
If they keep invoice low for import tax reasons it works out real good.
even here buying from usa works out cheaper than getting one sent in from japan which seems stupid !
12 Re: oil pump on 21st October 2015, 12:36 pm
luke s
Brilliant thank you you've beat me to it, Il get one orderd tonight.
13 Re: oil pump on 21st October 2015, 7:33 pm
luke s
well iv just orderd it and the total was $198 dollars so thats £128 pounds i think thats a bargain
and delivery is 2-5 days couldnt moan at that Smile
14 Re: oil pump on 21st October 2015, 8:52 pm
Well done mate .... a good saving from the nissan one .....
15 Re: oil pump on 22nd October 2015, 12:46 am
As above
16 Re: oil pump on 26th October 2015, 6:56 am
luke s
Sorry to ask another question, chain replacment kits, is there any need to replace the cam gears? Or just do the chain, tensioner and guides?
17 Re: oil pump on 26th October 2015, 11:51 am
Is there any wear on the cam gears ???
18 Re: oil pump on 26th October 2015, 11:58 am
luke s
Iv not had it out yet so don't know just getting parts ready for the rebuild that's all
19 Re: oil pump on 27th October 2015, 1:11 pm
Unless its thrown a rocker at some stage or engine has seized the chain and drive gear should be fine.
However if you do want a new chain, sprockets, guides and hex bolts I think I have some new ones in stock
                                GTI-R-US.CO.UK
                                          'Services provided'
20 Re: oil pump on 27th October 2015, 1:54 pm
luke s
Bob I remember speaking to you about starting up and a rattle for 1-2 seconds is that chain tensioner?
21 Re: oil pump on 27th October 2015, 6:34 pm
No that will be an oil flow issue which could well be the pump or a blockage somewhere, if chain, guides or tensioner is badly worn it wont go away after a couple seconds
                                GTI-R-US.CO.UK
                                          'Services provided'
22 Re: oil pump on 27th October 2015, 8:36 pm
luke s
It was a minor rattle just on start up, just for a second that's all
