Gtir Motorsport club » General Discusion » Random banter » Thoughts ?
Thoughts ?
1 Thoughts ? on 5th October 2015, 8:17 pm
Pulsar sr20 Det engine mated to a primera p10gt box what clutch to use looking for slight upgrade ?
2 Re: Thoughts ? on 5th October 2015, 8:41 pm
Is that a fwd gearbox or 4wd ???
3 Re: Thoughts ? on 5th October 2015, 8:50 pm
Fwd
4 Re: Thoughts ? on 5th October 2015, 9:03 pm
Yep fwd mate
5 Re: Thoughts ? on 5th October 2015, 9:07 pm
So would you have to change the flywheel ???
6 Re: Thoughts ? on 5th October 2015, 9:18 pm
Clucth it runs is slightly smaller will it be sunny gti or primera or ?
Standard fly mate
7 Re: Thoughts ? on 5th October 2015, 9:34 pm
measure current clutch, is it 18spline 200mm ! which would be primera p10
gti or w10 primera is 215mm but same 18spline i believe .
Have a look for something from competition clutch in required size ...
8 Re: Thoughts ? on 6th October 2015, 6:50 am
You would need a fwd sr20 flywheel, drill bolt holes on flywheel an extra 1mm or so to fit onto gtir crank.
Then just get an uprated fwd sr20 clutch.
Modified exhaust down/ front pipe.
Definitely keep a few clutch cables in the boot.
And run a fwd box with limited slip differential if you can or some other type of traction control/ phantom grip modification.
Last edited by Andy Sunny Gti on 6th October 2015, 10:01 am; edited 1 time in total
9 Re: Thoughts ? on 6th October 2015, 10:00 am
Wish I payed more attention when I done the box
10 Re: Thoughts ? on 6th October 2015, 10:02 am
Yeah will benefit going forward if you plan to run over 260bhp...
11 Re: Thoughts ? on 6th October 2015, 10:08 am
It runs 280 at the min I sure or around that and get very slight slip in  5th. Now it's just starting in 4th but so it should the thing is insane to drive and quicker than 300 bhp corsa turbo etc and who ever built the engine done well as without trying its on the red line and never caused any issues
It will one day but any doubters of these engines and reving them this car has massively restored my faith and reminds you the sr20 Det is still one hell of a engine
12 Re: Thoughts ? on 6th October 2015, 10:23 am
Yes the fwd sr20det can be a hoot to drive.
My old Sunny Fwd gtir ran 308bhp, but with now lsd.
My latest project, estimated completion date 2 years...
Running, SR20VET, fwd, lsd, coilover suspension, strut braces, big brakes, hks engine management. Can't wait till its done.
13 Re: Thoughts ? on 6th October 2015, 9:04 pm
Fwd are a lot of fun, I had a n14 4 door with an R motor. Disappointed I never really used it.
