Gtir Motorsport club » Tech room » Help and Advice » Gearbox oil seals
Gearbox oil seals
1 Gearbox oil seals on 15th October 2015, 7:20 pm
Rscozzy
Where can I get Gearbox oil seals where drive shaft enter gearbox carnt find part numbers or seal on Google my old seal have nok bw3684e and bw3691e
2 Re: Gearbox oil seals on 15th October 2015, 7:25 pm
engineers , bearing shops normally can match these, some motorfactors may or of course nissan
nissan part numbers can be found below ...
https://drive.google.com/file/d/0B7Ub2apq5-pfUlRubFhSN3M4cDQ/view
3 Re: Gearbox oil seals on 16th October 2015, 7:49 pm
Rscozzy
£20 from Nissan hope there correct 1s
4 Re: Gearbox oil seals on 16th October 2015, 7:59 pm
If don't want pay nissan prices take yours to a bearing/engineering shop as that about £4 a seal .
5 Re: Gearbox oil seals on 16th October 2015, 8:12 pm
nok bw3684e matches - 710214 or SKF 15353
nok bw3691e matches - 710246 or SKF 16596
6 Re: Gearbox oil seals on 16th October 2015, 8:31 pm
Rscozzy
Took them to Calder bearings in Wakefield they couldn't match them
7 Re: Gearbox oil seals on 16th October 2015, 8:35 pm
A decent supplier will, done it a few times on nok seals for driveshafts & prop flanges etc ...
8 Re: Gearbox oil seals on 16th October 2015, 8:45 pm
Rscozzy
Any on Google
9 Re: Gearbox oil seals on 16th October 2015, 11:45 pm
Look, you have the part numbers.
10 Re: Gearbox oil seals on 18th October 2015, 11:18 am
Dumb question but are these part numbers for driveshaft seals or propshaft seals?
My osf driveshaft transferbox seal is leaking slightly and need to get one, looking at the exploded diagram is it 33100h as its abit blurry
11 Re: Gearbox oil seals on 18th October 2015, 1:20 pm
^ driveshaft
all the seals are highlighted in red in the pdf link
OS transfer driveshaft seal is first one listed
Nissan P/N 33142-56E00 ( nok bw3684e matches - 710214 or SKF 15353 )
NS gearbox driveshaft seal is
Nissan P/N 38342-56E00 ( nok bw3691e matches - 710246 or SKF 16596 )
12 Re: Gearbox oil seals on 22nd October 2015, 7:10 pm
Thanks mate thats a great help
