Go to page : Previous  1 ... 9 ... 15, 16, 17, 18, 19, 20  Next
Go down  Message [Page 16 of 20]
376Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 3rd April 2016, 9:54 pm
Good luck with first start .
hope all goes well ...
377Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 10:29 am
It lives! It lives! bounce bounce bounce
Sparky did his stuff, i followed Bobs run procedure to the letter and it fired up and runs lovely.
No knocks, leaks, rattles, misfire.. (yet)
However it cuts out after about 20s but the sparky reckons thats because its a flat battery.
Im leaving it trickle charge for a good few hours and ill see if i can get it to run for a bit longer.
I'm over f&#ing moon.
The sparky removed the alarm and this is what came out...
Cosmic's Winter Pulsar Project - Page 16 Image12
378Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 10:41 am
Great news! And just in time for the show season. Amazing how much cabling there is in these alarm systems my cousins imobiliser went squiffy on a spring day (north weild when Bob run the event) and we spend an hour chopping it out with tiny scissors from my Mrs handbag lol bastard things
379Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 11:13 am
Yep, just in time for Japfest which gives me about 3 weeks to mot it.
Alarm wiring is a mess, glad its out. Its just more to go wrong in my book, especially with an ancient one like that Clifford.
380Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 11:19 am
Woohoo! Nice one, glad it's all running, well for 20 seconds at a time Laughing
381Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 7:44 pm
This is very strange,
It starts straight away and purrs like a kitten for 10 seconds then stalls!
Its done this now for about 40 starts,
Longest ive had it running is about 30seconds by blipping the accelerator but it doesnt seem to catch.
Ive checked the following;
Fuel inlet is presserised, squirts fuel out and is connected to the inlet,
New fuel filter fitted,
Spark plugs are cleaned and gapped at 0.9mm,
Spark plugs were put in an oven at 140c and refitted,
Dizzy is in the middle position,
Dizzy contacts cleaned,
No sign of rotor arm unscrewing,
Timing is spot on,
I unclipped the afm and it made no difference,
Any thoughts anyone???
anyone?
382Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 7:58 pm
Did you charge the battery in the end? Would be unlikely to start and stop 40 times though if its dead its dead.
Does seem a strange one, so if you give it a bit of throttle it still dies?
Try not to do it too much on a fresh engine as flooding it wont help it all and may fill your oil with fuel
383Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 8:31 pm
Just out curiosity you did put your fuel lines right way around?? Return where fuel pressure reg is? I wouldn't say is overfueling cos it would idle up way too high... Oh and good job getting it back together thumbsup
384Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 8:32 pm
Yeah, battery's fine, loads of charge,
Plugs are dry so i dont think its flooding,
385Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 8:34 pm
@Gostek wrote:Just out curiosity you did put your fuel lines right way around?? Return where fuel pressure reg is? I wouldn't say is overfueling cos it would idle up way too high... Oh and good job getting it back together  thumbsup
Fuel line is defintley the right way round,
Ill buy some easy start tomorrow and see if its a stale fuel issue,
If that doesnt work it can only be a sensor fault??
386Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 8:39 pm
@Cosmic73 wrote:Yeah, battery's fine, loads of charge,
I think it's other way round its not getting fuel
This said to start so many times it's getting some but something ain't right
387Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 8:41 pm
I think I argued this last time or people were saying not. How long has it been off the road ?
I know fuel goes stale but how many people actully can truly say it was 100% stale fuel only and how long has the car sat for this to happen
388Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 8:50 pm
Its been off the road since i bought it in October last year, so 6 months maybe,
I dont think it is stale fuel, 6 months is nowt really.
If its getting no fuel how it come it fires up and runs for 10seconds?
Bob supplied refurbed injectors so fuel should be pissing out right?
Also how do do dial up the fuel mix?
Smile
389Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 8:57 pm
Good to hear it's running ish.
Check the voltage on your fuel pump.
When you stop and start it every time the fuel pump will purge. But might not be strong enough to keep it pumping fuel?
390Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 8:58 pm
Have you done a fault code check also?
391Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 9:01 pm
Would it be anything like the cold start valve? Not plugged in, closing up too early? What rpm is it idling at before it dies?
392Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 9:07 pm
@burrows1980 wrote:Would it be anything like the cold start valve? Not plugged in, closing up too early? What rpm is it idling at before it dies?
I dont have a code reader,
idles strongly around 800rpm
Ill unplug the cold start valve tomorrow and see what difference that makes,
Cheers
Very Happy
393Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 9:10 pm
Surely it should be idling higher from a cold start? Around the 1500 mark?
394Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 9:43 pm
Very Happy
You dont need one. Just a piece of wire Wink
http://www.gtir-motorsport-club.com/t81-ecu-fault-code-check
395Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 6th April 2016, 10:55 pm
I would do as said above & check cold idle valves & also fueling.
my hunch is fuel pressures as when key turned it on (initial prime) then not coming on again so dies ! could link into wiring as fuel pump would deffo been in a cat1 alarm cut circuit.
You could easily wire a fused hardline to power the pump or monitor pump voltage/operation to try eliminate/prove it .
Plenty other things so keep open mind but rule that pump out & do fault code check as they easy areas to start with .
Least it didn't rattle or explode lol thumbsup good luck ...
396Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 7th April 2016, 12:05 am
First off you said plugs are gapped to 0.9 which is to large a gap
Bring them down to 0.7mm
Like others I believe it's a fuel related problem, now assuming there is still not an issue with the way alarm was removed I would guess there's either a pump issue as its been left a while and pumps can seize not giving full flow or the filter in tank has a residue on it which is not allowing fuel to be sucked up but soon as pump is turned off the residue disperses a little allowing it to run momentarily until it stifles again and engine will then eventually cut
So in short remove pump from tank and carefully inspect the filter to see if it looks like a wrinkled prune, if so temporarily remove it and just fit a pipe on it and try it. Whilst it's out give the pump a couple of clouts with a hammer as this will dislodge any matter that could be partially causing it to seize, my guess is this will resolve your issues
397Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 7th April 2016, 5:24 am
Fuel at rail but would the injector resistor pack be playing up meaning it's not letting the fuel through ?
398Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 7th April 2016, 7:52 am
Fuel is definitely flowing in and out the correctly connected fuel rails, with very healthy pressure,
Fuel pump primes no problem,
Sparky said there was no immobiliser wiring to the fuel pump, it was left alone,
Checked cold start valve and it's connected,
Tonight i'll check the fuel pump filter as i think this all points to fuel starvation, (plugs are very dry).
I'll also re-gap to 0.7mm
Top drawer advice everyone thanks,
Very Happy  Very Happy  Very Happy
399Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 7th April 2016, 10:26 am
Maybe your R was owned by one of those "car shaggers" who do it with their car. Might be residual goo down your filler neck and in the tank lol
400Cosmic's Winter Pulsar Project - Page 16 Empty Re: Cosmic's Winter Pulsar Project on 7th April 2016, 10:51 am
Hard wire the fuel pump straight to the Battery and monitor the fuel pressure. Also check fuel tank breather.
Back to top  Message [Page 16 of 20]
