bool(false) Cosmic's Winter Pulsar Project - Page 17
Go to page : Previous  1 ... 10 ... 16, 17, 18, 19, 20  Next
Go down  Message [Page 17 of 20]
401Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 7th April 2016, 12:39 pm
^ That what I would try, would also check voltage first at pump when cranking & briefly starts as if no voltage or very low then that would indicate feed to pump when engine running has issue.
initial prime is time output from ecu & engine would run some seconds on the line pressure .
It started when you bought it as remember you saying about the knocking so not been stood long since then has it !
Everything points to wiring still not A1 (sparkies comment on battery issue bit off so his wiring may not of been perfect either) and if is wiring it probably easiest & cheapest fix .
402Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 7th April 2016, 2:28 pm
I would just break it mate free yourself from a future of torment and perril. I will happily take that gearbox off your hands for two new born lambs and half a tonne of hardcore
403Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 7th April 2016, 6:45 pm
@Mr B wrote:^ That what I would try, would also check voltage first at pump when cranking & briefly starts as if no voltage or very low then that would indicate feed to pump when engine running has issue.
Cheers Mr B,
Ill try hotwiring the fuel pump and see if that helps,
Itll also give me the chance to inspect the pump filter.
I think you may be right the the sparky missed a wire to the fuel pump. I was surprised when he said the immobiliser wasnt linked to it.
Anyway ill soon find out.
Very Happy
404Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 7th April 2016, 6:50 pm
@shroom wrote:I would just break it mate free yourself from a future of torment and perril. I will happily take that gearbox off your hands for two new born lambs and half a tonne of hardcore
If its half a tonne of hardcore smut involving sheep and 5lb of chip fat, its a deal!
thumbsup
405Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 7th April 2016, 9:22 pm
^ Shocked lol!
406Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 7th April 2016, 9:33 pm
thumbsup
Haha you even got the welshmans attention then! Chip fat!? Oh no no im gonna use grandmars lard warm it up in hand and it will be useful.
Do you think you will get her working over the weekend then :-)
407Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 7th April 2016, 9:41 pm
Hope so, lucks gotta change some time
Laughing
408Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 7th April 2016, 9:48 pm
If you have multimeter (basic cheap meter all needed) you want test earth & voltage at the 2 wire plug on fuel pump.
ECU controls the switching of the pump on pin 104 of ecu, this switches to ground & is the ground wire on switch side of pump relay, Ecu has initial timed prime when it switches pin 104 to earth & then also switches when it detect engine cranking/running .
If unlucky it ecu control circuit issue when cranking/running > this would be evident by pin 104 not switching ground & no voltage at pump terminal
Other issues could be low voltage due to various wiring faults or relay fault > this could seen by low voltage at pump and if quickly run a temp direct +ve feed to pump fact it cures running issue.
If this checks ok then investigating pump (pump mounting & pickup socks get some right bodges so will be wise check it out) & as ducie suggested adding a fuel pressure gauge would be useful data.
Most of this takes ages to talk about but a minute to do and hopes are you'll stumble on irregularity quite quickly !
doing fault code check & clearing all codes is good idea too . I make sure mine are all checked & cleared as new engine new slate, then can be checked again to see all clear or something amiss & you know results all post build .
* how does it die off, does it smoothly dip down in revs till cut out or a sudden stall or spluttery missfire stall !
Lack of fuel pressure should be more like first scenario .
409Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 7th April 2016, 11:23 pm
Man your posts are entertaining I don't where you come up with this stuff lol
410Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 7th April 2016, 11:38 pm
" a sick sick place called Shropshire lol :-) A man with 2 R's & lust of sheep is as demented to the max :-D
411Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 8th April 2016, 7:28 am
Well in truth I mostly dont have anything technical to add so just spout some mildly entertaining rubbish from time to time usually related to sheep or the likes lol.
I think it lifts cosmics hopes as we all know how anoying things can get!
412Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 8th April 2016, 8:04 am
I totally agree, its nice to work hard but what's the point if its not fun and you can't have a laugh.
Rep point earned for your outstanding attitude to life's little ups and downs.
Very Happy
413Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 8th April 2016, 9:00 am
@Mr B wrote:" a sick sick place called Shropshire lol :-) A man with 2 R's & lust of sheep is as demented to the max :-D
This is true. I used to live accross the water from where shroom lives and its folk law that those accross the water have webbed feet and walk the streets in nothing but a loin cloth Laughing they are as mad as a hatter over there and if you venture over the water you risk never returning home sain Laughing
414Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 8th April 2016, 7:12 pm
@Stu wrote:
@Cosmic73 wrote:
@burrows1980 wrote:Would it be anything like the cold start valve? Not plugged in, closing up too early? What rpm is it idling at before it dies?
I dont have a code reader,
Very Happy
You dont need one.  Just a piece of wire Wink
http://www.gtir-motorsport-club.com/t81-ecu-fault-code-check
Cheers Stu,
As soon as i came in from work i read a 12 code (AFM),
So i unclipped the connection and clipped it back in and the code read 55 (all ok),
I sprayed a load of easystart and it fired up but kept stalling without the easystart.
However if unplugged this blue wire it ran for much longer, i even got it to 2,500rpm for a couple of minutes, but the slightest dip in throttle just stalls it. This is progress because i can rule out the fuel pump.
This blue wire runs out the afm connector direct to the -ve battery terminal.
Anyone have any ideas what it might be for?
Smile  Smile  Smile
Cosmic's Winter Pulsar Project - Page 17 Image14
415Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 8th April 2016, 7:16 pm
Earthing kit lol... Sometimes earth from ecu is getting weak so people (me included) run wire straight from battery negative just make sure is wired in where it should be not to signal or +. Oh and easy on easy start...You might do some damage with this stuff....
416Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 8th April 2016, 8:11 pm
Can i see a picture of your engine bay please. See if theres anything that looks wrong..
Check the fuses in the engine bay that are on passenger side. You may have blown the engine fuse. Should be a brown square fuse.
417Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 8th April 2016, 8:22 pm
looks a bodgy effort on the crimped earth wire. most original earths are fine if checked cleaned .
least making some conclusions. worth pulling out the R bible & doing all basic tests on afm harness & afm itself, check everything ecu end too for potential bodgy joins in harness were piggyback etc may of once intercepted the harness & also on wiring that lead to initial no ignition as that still may have something amiss. Check harnesses connectors thoroughly around engine bay. Run through all intake pipes/vacuum pipes again too as this easy area have a glitch & possibly cause similar running issue .
Hopefully bit more investigation will lead to an answer.
418Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 10th April 2016, 4:47 pm
Diagnostics is way above my skill set so im arranging fir it to be trailered to Bobs in the next few weeks,
However i can manage a bit of cleaning, so i removed and cleaned the afm with contact cleaner. The sensors were black but now they're a nice silver colour. I also realised one of the plug leads wasnt fully pushed into the dizzy cap.  Rolling Eyes
P
Tried to start the car 3 times and same story, stalls after a few seconds. Mad
So i disconected that blue earth lead from the afm and it for the first time it fired up and idled perfectly!!!! Razz  Razz  Razz
But as soon as i reconnect that blue lead it instantly kills the car, watch this vid; wtf!  wtf!
Cosmic's Winter Pulsar Project - Page 17 Th_IMG_0589_zpse6mpym6g
419Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 10th April 2016, 5:04 pm
What pin is that lead going to on maf plug ?
420Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 10th April 2016, 5:37 pm
As Stu posted diagnostics are a peice of piss on this car short the pins and it will flash the engine light as a code thats it. If you mean actually sorting the issue then seems like its that "earth" or cable causing some issues as Johhny says check its actually going to the earth and just do away with it.
421Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 10th April 2016, 6:14 pm
@johnny gtir wrote:What pin is that lead going to on maf plug ?
It just goes to -ve battery terminal, Mike reckons its to help earth it.
422Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 10th April 2016, 6:21 pm
@Cosmic73 wrote:Diagnostics is way above my skill set so im arranging fir it to be trailered to Bobs in the next few weeks,
P
Wish i never posted this now,
Tried to start it again after dinner but having exactly the same problem again!!
duh duh
Ive got no idea what the fucks going on,
2 things i did notice,
Spark plugs are now totally coked up, maybe its from emptying a whole can if easystart into it.
Boost gauge read -3 when it did idle,
Ive had enough now, im sure Bob will pinpoint the problem.
423Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 10th April 2016, 6:31 pm
@Stu wrote:Can i see a picture of your engine bay please. See if theres anything that looks wrong..
Sorry for the delay in posting these Stu,
I checked the fuses snd they are all fine,
Error code is still 12, amf.
Very Happy
Cosmic's Winter Pulsar Project - Page 17 Image20
Cosmic's Winter Pulsar Project - Page 17 Image21
Cosmic's Winter Pulsar Project - Page 17 Image23
Cosmic's Winter Pulsar Project - Page 17 Image22
424Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 10th April 2016, 6:39 pm
I've just checked this earth wire goes to white one on maf...
425Cosmic's Winter Pulsar Project - Page 17 Empty Re: Cosmic's Winter Pulsar Project on 10th April 2016, 7:57 pm
One thing though the head sounds nice and quiet thumbsup
Back to top  Message [Page 17 of 20]
