Go to page : Previous  1 ... 10 ... 17, 18, 19, 20  Next
Go down  Message [Page 18 of 20]
426Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 10th April 2016, 8:43 pm
@Cosmic73 wrote:
@johnny gtir wrote:What pin is that lead going to on maf plug ?
It just goes to -ve battery terminal, Mike reckons its to help earth it.
Is that where it deffi goes ? I think something ain't connected from the original loom to maf ? What's story with the car when did it last run ? What's been changed ?
No more easy start if I were you and I still say it's fuel/maf playing up
427Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 10th April 2016, 8:49 pm
@burrows1980 wrote:One thing though the head sounds nice and quiet thumbsup
Cheers, at least thats one thing i got right,
Laughing
428Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 10th April 2016, 9:46 pm
Its always been connected like that, ive never changed it,
Heres a photo i took befire i stripped it showing the exact same wire going to -ve battery terminal,
Cosmic's Winter Pulsar Project - Page 18 Image24
The car last run when i bought it last October, it fired up and idled fine although it serious big end damage,
I removed the alarm siren and its wiring, sparky removed the remaining immobiliser and connections,
Thinking about it feels like i might have removed a joint earth wire, which is why it runs much better after its been left alone for a day,
Ive got a multimeter so tomorrow after work ill do some basic voltage checks on afm and tps.
429Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 11th April 2016, 8:48 am
If you are still getting afm fault code. Thats the main issue. Have you cleared the code and it comes back?
The hard pipe from turbo to afm might be another issue. The angle may no be quite right. Like mine. Try a piece of womans tights between the afm and hardpipe to see if it helps any.
But also take the afm out of its couling and spray the element with some electrical cleaner.
430Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 11th April 2016, 9:04 am
@Stu wrote:If you are still getting afm fault code. Thats the main issue. Have you cleared the code and it comes back?
How do i clear the code? Neutral
The hard pipe from turbo to afm might be another issue. The angle may no be quite right. Like mine. Try a piece of womans tights between the afm and hardpipe to see if it helps any. Ooh kinky,i'll try it but use my tights instead  Wink  Wink
I done this already, Very Happy
431Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 11th April 2016, 9:36 am
To clear the codes you need to do the procedure as usual and then do it again straight after. This should clear the codes. Do the procedure again and you should get 5 long and 5 short.
Make sure you take your tights off first and dont use the gusset. You dont want to get ya cock stuck in the afm Laughing
432Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 11th April 2016, 9:41 am
We're you the one running a different standalone Ecu ?
433Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 11th April 2016, 10:13 am
@johnny gtir wrote:We're you the one running a different standalone  Ecu ?
No I think that was bandyleg.
I think cosmic has checked his ecu to make sure its stock?
Those lambs and hardcore are still waiting Smile
434Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 11th April 2016, 10:13 am
@Stu wrote:To clear the codes you need to do the procedure as usual and then do it again straight after. This should clear the codes. Do the procedure again and you should get 5 long and 5 short.
Haha there is a man speaking from experiance
435Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 11th April 2016, 6:56 pm
Ok, so ive just done my first 'diagnostics' with my multimeter, ooh!
Do these voltages make sense to anyone?
Very Happy  Very Happy
Afm (with that earth wire connected)
Orange wire on the right, 12v
White wire in the middle, 0v,
Orange wire on the left, 0.52v but increases to 3v when i blow in the sensor,
Afm (with that earth wire not connected)
All wires read approx 11v,
Cosmic's Winter Pulsar Project - Page 18 Image25
Tps,
Red wire, 5.1v,
White wire, 0.52v but increases to 4.3v when i turn accelerator,
Black wire, 0.02v
436Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 11th April 2016, 9:33 pm
Ive done a bit of research and those voltages are all spot on so that earth wire is defintly doing its job which means the amf and tps are working fine.
Ive just done a cold compression test and that looks fine too,170, 170, 140, 170,
Tomorrow ill buy some new bcr8es plugs and see if those make a difference,
After that i can only think of blocked injectors??
study
437Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 11th April 2016, 10:20 pm
Why are you still getting a code for the afm on the fault code check tho?
Have you cleared it? It could be that the code hasnt been cleared so the ecu is still registered as an afm fault..
Did you try the tights?
438Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 12th April 2016, 8:38 am
@Stu wrote:Why are you still getting a code for the afm on the fault code check tho?
No sorry, i didn't clear it, i only learned how yesterday. i will do it this evening  Smile
Do old codes change how the engine runs?
Not yet, i want to wear them in a bit first  Shocked , but i will try this evening,
Smile
I'm also going to drain the fuel and use fresh stuff,
Can anyone confirm that i simply remove the pipe after the fuel filter and do it that way??
439Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 12th April 2016, 9:59 am
I think I'd worry about why the original earthing on the afm is broken/disconnected and try and track it down. Might be something else missing an earth for the same reason.
440Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 12th April 2016, 10:48 am
In the words of Toyah,
"Its a mystery, oh its a mystery"
suicide
441Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 12th April 2016, 10:53 am
Yeah just clear that code as until its cleared it will effect the running.
442Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 12th April 2016, 10:55 am
exactully the route I was heading john when I commented what had changed and thought he was the one who removed a standalone Ecu that had its own sensors
443Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 15th April 2016, 6:24 pm
Cleared the code, and the afm is fine, Smile
Bypassed the fuel pump wiring with a direct power and the car starts, idles and revs fine.
run run
After all that it was the twat of a sparky not removing the immobiliser properly,
Ill be having words in the morning Evil or Very Mad
Just want to say
thanks.
To everyone for their help, Very Happy
444Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 15th April 2016, 8:27 pm
Glad to hear! you must be very excited Smile
445Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 15th April 2016, 9:06 pm
Over the moon mate,
Very Happy
446Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 16th April 2016, 1:15 am
Cosmic's Winter Pulsar Project - Page 18 12821310 Cosmic's Winter Pulsar Project - Page 18 Spanne10
447Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 16th April 2016, 8:01 am
Gotta hand it to you mate, youve put lots of work into this thumbsup
448Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 16th April 2016, 8:08 am
Cheers, although at times it was more like this,
shit hit the fan cant fix it
449Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 16th April 2016, 10:34 am
Sparky came back this morning and after a bit if head scratching discovered there was still a fuel cut off attached Embarassed
Cosmic's Winter Pulsar Project - Page 18 Image26
Anyway, now that all signs of the immobilsier are finaaly removed it runs fine,
Got its mot booked on monday morning too Very Happy
450Cosmic's Winter Pulsar Project - Page 18 Empty Re: Cosmic's Winter Pulsar Project on 16th April 2016, 3:43 pm
Well done. Good luck with the MOT.
Back to top  Message [Page 18 of 20]
