Gtir Motorsport club » Tech room » Help and Advice » evo brakes
evo brakes
1 evo brakes on 25th October 2015, 7:36 pm
Listed as evo4 but they are exactly the same as evo3 ones that i have seen. So hopefully they are the correct ones for the evo conversion?
Can't believe the price i have got them for Laughing
2 Re: evo brakes on 25th October 2015, 7:49 pm
Animaldaz
You jammy git .
I've been considering doing this conversion so I can  fit 15's but as i already have brembo 4 pots it seems a bit daft.
3 Re: evo brakes on 25th October 2015, 8:05 pm
If they from the evo 4 it will be the rs version & have 160mm bolt spacing (as hubs designed for brembo as well) on the caliper bracket that don't match up as we need 130mm hole spacing.
If this is the case not to worry as can just get some 130mm spaced brackets.
If you use the outlander brackets you can use 294 evo discs, done thread on that (search akebono)
If use galant or evo3 etc brackets you can use 280 clio or correct size 276 evo discs.
Edit: evo 5 would be rs for 2 pot, evo4 any but they still on the 160mm spacing hub as far as I remember.
4 Re: evo brakes on 25th October 2015, 8:10 pm
Good work Stu, always great grabbing a bargain.
5 Re: evo brakes on 25th October 2015, 8:18 pm
@Mr B wrote:If they from the evo 4 it will be the rs version & have 160mm bolt spacing (as hubs designed for brembo as well) on the caliper bracket that don't match up as we need 130mm hole spacing.
Ah okay. I will measure the spacing when they arrive.
Thanks for the info MrB.
@gtir_woody wrote:Good work Stu, always great grabbing a bargain.
Thanks mate. Smile
6 Re: evo brakes on 25th October 2015, 8:21 pm
The guy selling them said they were an upgrade for the 1. 2 and 3 on his listing. Thats why i bid. Thinking maybe they were a dirrect fit for the evo3.. we will see.
7 Re: evo brakes on 25th October 2015, 9:03 pm
I have searched for 160mm to 130mm brackets but cant find any info on them.
If i do fit that bracket on the calipers to hubs. What size brake disk will i need?
Does anyone have any measurements of the brackets so i can get some made up?
8 Re: evo brakes on 25th October 2015, 9:05 pm
I'm 99% sure the evo 4 hubs are setup with 160mm mount bolt pattern while 1 to 3 had the more common 130mm. you can buy pattern part brackets so if needed either get evo 3/galant if want 276mm brakes or the outlander bracket if want 294 brakes.
9 Re: evo brakes on 25th October 2015, 9:08 pm
@Stu wrote:I have searched for 160mm to 130mm brackets but cant find any info on them.
here's my akebono thread.
http://www.gtir-motorsport-club.com/t4937-akebono-2pot-floating-294mm-brake-upgrade
I can dig up part numbers for evo3/galant brackets if need I expect.
10 Re: evo brakes on 25th October 2015, 9:26 pm
Thanks B
11 Re: evo brakes on 25th October 2015, 9:38 pm
Looks like a load of hassle Sad
If the carriers are 160mm i will just stick them back on ebay lol
Evo 3 conversion is much easier Smile
12 Re: evo brakes on 25th October 2015, 10:12 pm
gtir350
FTO Wink
13 Re: evo brakes on 25th October 2015, 10:18 pm
If calipers look clean I would keep them as getting hard pick up good ones, you should be able find 130mm spaced caliper brackets same as galant/evo3< if look around.
Could even be 130mm then you laughing.
294mm discs is almost as easy as only difference is need of bore ring adaptor & drilling discs to 4 stud pattern & buying 2 outlander caliper brackets.
14 Re: evo brakes on 31st October 2015, 11:35 am
They have arrived. And are 160mm Sad
Need to look out for some brackets now and sort some disks out.
15 Re: evo brakes on 31st October 2015, 1:05 pm
I i have to use the 294 disks with these brakes. Does that mean they wont fit under 15" wheels?
16 Re: evo brakes on 31st October 2015, 2:18 pm
really depends on wheel design & offset, caliper would be tight/foul on most 15" I expect
could mock up disk position/edge from bit of ply/timber using 294 disk details then wedge calliper to that & test with wheel.
17 Re: evo brakes on 31st October 2015, 2:41 pm
@Mr B wrote:really depends on wheel design & offset, caliper would be tight/foul on most 15" I expect
Can't be arsed with all the messing about lol
I have Put them on ebay for a flip Smile let someone else have the conversion.
Im gonna buy some evo 3 brakes i stead Smile
18 Re: evo brakes on 31st October 2015, 10:07 pm
Good plan, don't worry messing around with them, just get the evo3 calipers and make life easier Smile
19 Re: evo brakes on 31st October 2015, 10:35 pm
caliper is same, you could just try sourcing the 130mm spaced 276mm disc bracket which same on evo 1,2,3 , galant , fto-gpx and other mitsi's with 276mm discs & akebono's
20 Re: evo brakes on 1st November 2015, 5:52 am
Similar to the brackets I brought for my maxima rear upgrade B?
21 Re: evo brakes on 1st November 2015, 7:37 am
Did you buy them to space the standard caliper woody ?
22 Re: evo brakes on 1st November 2015, 7:54 am
Yeah those were the ones to offset the calipers for the bigger rotors Johnny
23 Re: evo brakes on 1st November 2015, 12:38 pm
@gtir_woody wrote:Similar to the brackets I brought for my maxima rear upgrade B?
yes, same concept
24 Re: evo brakes on 1st November 2015, 6:51 pm
the narrow (130mm) caliper mount bracket is mitsubishi P/N MB618218
