Gtir Motorsport club » Tech room » Help and Advice » Head gasket
Head gasket
1 Head gasket on 29th October 2015, 6:12 pm
Rscozzy
What's best way to open up the guide holes on head gasket (the two dowel what line head up to block )
2 Re: Head gasket on 29th October 2015, 6:50 pm
File or sharp dril bit on flat steady surface ie clamp gasket to wood so you can drill it and into the scrap piece of wood should stop it twisting. Someone else might have a better idea
3 Re: Head gasket on 29th October 2015, 8:51 pm
Thats how ive done them in the past with a drill and a piece of wood just go up size by size with drill bits ...
4 Re: Head gasket on 30th October 2015, 5:17 pm
file, hand reamer, die grinder . only about half mm . just do it with lot of care.
5 Re: Head gasket on 30th October 2015, 6:07 pm
Rscozzy
Just used reamers thanks For advise
