Gtir Motorsport club » General Discusion » Gtir related Discussion » luck aint on my side right now
26 Re: luck aint on my side right now on 5th November 2015, 11:27 am
@nomad wrote:Have they pulled the top of the door out to gain access sye ???
yeah with a crowbar or something, pryed it out so they could get to the lock on the inside.
Yeah not holding my breath about it tbh, given me a little bit of encouragment to get the electrics all sorted now and focus on security
27 Re: luck aint on my side right now on 5th November 2015, 12:18 pm
Best thing with security is be a bit sneaky .
alarms are handy but any clued up jacker will bypass most ones in 10 minutes, especially when common ones pro installed, home installed can be nightmare if wiring like a can of exploded spaghetti & alarm a ebay special .
something as simple as a very well hidden switch cutting an ecu feed can really stop car from running more than any cat1 alarm.
Think can conclude from damage they kids & not too good at it :-S
Are you paying out your own pocket, doubt worth using insurance with excess & then increased future policy costs :-(
Least you seem motivated sort it which good, best to gain strength from the experience.
Hope things work out okay ....
28 Re: luck aint on my side right now on 5th November 2015, 3:39 pm
if you need an ignition key / lock assembly then I have one you can have as a freebie, just cover postage costs sye seeing as your a good lad.
really sorry to hear they did this but that's life unfortunately nowadays, small minded little fukwits after drug money no doubt Rolling Eyes
29 Re: luck aint on my side right now on 5th November 2015, 10:05 pm
seems like i only need the switch/harness bit which is behind the ignition barrel and the button which you push to release the key, if thats what part you mean?
cheers very much, really appreciated
30 Re: luck aint on my side right now on 10th November 2015, 9:09 am
@Mr B wrote:Best thing with security is be a bit sneaky .
hey thanks for that i didnt even think about a killswitch, i done some reading and they advise not to do the ecu as it might damage it bu what about the fuel pump? i could run a switch from the new wiring for walbro? easy enough to do?
31 Re: luck aint on my side right now on 10th November 2015, 10:43 am
Rather than a kill switch fit one of the battery idolaters that come with. Key
32 Re: luck aint on my side right now on 10th November 2015, 1:10 pm
You want be sneaky
fuel & starter are common ones be cut for immobiliser
ideally you want run of mill alarm on those circuits then add hidden push switch to cut relay for ecu power feed & do wiring on it as oem neat & hidden as possible. this way they do the norm work on alarm & then if cranking but not starting they wasting time, making noise & end up with wheezy battery too.
I have a small push switch under handbrake soft trim & can only push magic spot when handbrake on. Just do it with quality switch & soldered joints & it will be reliable.
You can do a decent hidden cut switch for less than price of takeaway.
half decent cat1 alarms are cheap these days too, I like the dual zone proximity sensors as a nasty noise while poking around with doors etc prior to entry pisses them off & gives hint it may be not worth the hassle
3 things they hate is noise, time & flashing lights lol .
