Gtir Motorsport club » Tech room » Help and Advice » Reverse Lights No go
1Reverse Lights No go Empty Reverse Lights No go on 15th November 2015, 2:06 am
SIR GTI-R
SIR GTI-R
Hey Everyone after a small win on fixing my lack of taillights Burnt contact to parklight,dashlight rocker on the headlight stork
Am I correct thinking the neutral switch and reverse are the same item??
the black plug at the bottom of the G/Box with 4 pin plug attached
im worried bout feeding 12v to them and spiking the ecu or something dumb
2Reverse Lights No go Empty Re: Reverse Lights No go on 15th November 2015, 2:58 am
Reverse Lights No go Neutral_reverse_switch
3Reverse Lights No go Empty Re: Reverse Lights No go on 15th November 2015, 5:04 am
SIR GTI-R
SIR GTI-R
@Mr B wrote:Reverse Lights No go Neutral_reverse_switch
dam what page of the manual is that on
I tried probing all the pins got a circuit 1-3 neutral side nothing from the other Rolling Eyes
guessing the oils going to pour out if I remove it
thanks Mr B
4Reverse Lights No go Empty Re: Reverse Lights No go on 15th November 2015, 11:40 am
I normally bridge a piece of wire between the two pins that way if its the switch  it will put the reverse lights on if it doesnt then its a wiring issue ...
5Reverse Lights No go Empty Re: Reverse Lights No go on 15th November 2015, 12:32 pm
pin 3-4 should be open circuit if out of reverse, in reverse you will have circuit/continuity .
Nomads tip is good too as if bridge 3-4 pins in harness plug reverse lights should come on if wiring/bulbs/clusters all good .
some oil will indeed come out when switch removed, either be prepared & do quick swap or drain completely for cleaner option
page 1283
6Reverse Lights No go Empty Re: Reverse Lights No go on 15th November 2015, 2:43 pm
Sprry to hijack I have an issue that when I put it into reverse the lights dont come on but if I then move the stick a mm or so forward the light comes on. Is there a sensor for this or is something worn?
7Reverse Lights No go Empty Re: Reverse Lights No go on 15th November 2015, 6:11 pm
^ wear I would of thought, depends if more reverse mechanism or wear or switch wear .
Could be worth removing & inspecting switch, refit repositioned slightly such as machined slightly so screws in bit more or spaced out bit if helps function .
could also try another switch as a new switch might have more function range which could overcome internal mechanism wear .
8Reverse Lights No go Empty Re: Reverse Lights No go on 15th November 2015, 8:17 pm
Ive always done it that way on all different makes its just a quick way of seeing wich is at fault switch or wiring issue ....
9Reverse Lights No go Empty Re: Reverse Lights No go on 16th November 2015, 4:17 am
SIR GTI-R
SIR GTI-R
@shroom wrote:Sprry to hijack I have an issue that when I put it into reverse the lights dont come on but if I then move the stick a mm or so forward the light comes on. Is there a sensor for this or is something worn?
Come to think of it
Mine was the same bit of a wiggle of the stick they worked but yeah that trick doesn't work any more
10Reverse Lights No go Empty Re: Reverse Lights No go on 16th November 2015, 11:13 am
If the gearbox sensor does need to be removed........jack the car up around 18'' on passenger side and you wont lose much if any oil at all, saves draining and refilling. Be warned though they can easily break if trying to remove from outside the box so if you don't have another to go in then get some Araldite or epoxy resin as you may need to reseal it if the casing cracks
11Reverse Lights No go Empty Re: Reverse Lights No go on 17th November 2015, 8:03 am
SIR GTI-R
SIR GTI-R
thanks everyone I'll keep you in the loop once cured
12Reverse Lights No go Empty Re: Reverse Lights No go on 21st November 2015, 1:02 am
SIR GTI-R
SIR GTI-R
ok so judging by the fact theres no circuit on the reverse side of the plug
Tested the neutral as well to be sure no trouble there
so theres nothing tricky about the removal other than actually getting it to move ??
13Reverse Lights No go Empty Re: Reverse Lights No go on 21st November 2015, 2:37 am
Just wiggle it gently to try get it move & spray little release oil as may help, once wiggles a bit try prying & wiggling gently.
Once out you will see switch contact points & a contact slipper that comes out separate, hopefully you will see an issue with parts once apart, I had success with one just cleaning contacts & repositioning slightly as worked better twisted off a degree or 2 so elongated screw hole to suite.
If seems real tight I would try get a spare first, they used on fair few nissans so may source one in a salvage yard or good parts supplier local or online.
14Reverse Lights No go Empty Re: Reverse Lights No go on 21st November 2015, 8:36 am
SIR GTI-R
SIR GTI-R
you the man thanks Mr B
15Reverse Lights No go Empty Re: Reverse Lights No go on 3rd January 2017, 10:30 pm
SIR GTI-R
SIR GTI-R
since bridged in a switch to the reverse switch side of the plug and the lights work need to talk to my friend at the dealer and see if I can get a new switch as trying to find a used one seems difficult
16Reverse Lights No go Empty Re: Reverse Lights No go on 3rd January 2017, 10:35 pm
Switch will be fine just clean the copper contact pad and bend the small plate under it.
