Gtir Motorsport club » General Discusion » Random banter » Spa gauges
Spa gauges
26 Re: Spa gauges on 21st November 2015, 11:40 pm
you got a link for the 12v one johnny
27 Re: Spa gauges on 22nd November 2015, 7:22 am
@johnny gtir wrote:There over 52mm if using gauge holder of any type. The pressure sensors are big and bulky. The water one goes in a sensor holder so not to bad. The boost one has to be T pieced into a threaded t piece. Set up on them is a little crazy. Ue boost one you have to turn alarm off low boost or it goes off soon as it vacumes. So guess it's made for pure boost line on different vehicles. Just found them fiddley for few reasons.
All this said a nice gauge once set up. Just slightly over complicated for most people's needs. Think I have photos if you need for how I taped into achive readings
Yes Johnny if you have id really appreciate that thanks!
28 Re: Spa gauges on 22nd November 2015, 7:49 am
Mr b e bay is your friend lots of options. One here just numbers I will put another link up but please check size voltage etc I will see if there is a link for step down aswell
http://m.ebay.co.uk/itm/Red-LED-DC-12V-Digital-Thermometer-Sensor-Probe-50-110C-Temperature-Detector-/321716635412?nav=SEARCH
29 Re: Spa gauges on 22nd November 2015, 7:51 am
http://m.ebay.co.uk/itm/dc-12v-Digital-led-Thermometer-Meter-4pin-pc-Computer-MOD-Temperature-1M-probe-/400731367108?nav=SEARCH
Check its size
Let the rep points flow as above item is one of the little touches quite unique to my car will be a common mod now ha ha
30 Re: Spa gauges on 22nd November 2015, 7:55 am
http://m.ebay.co.uk/itm/DC-DC-Converter-Module-12V-To-5V-3A-With-USB-Output-Power-Adapter-15W-Regulator-/261879560216?nav=SEARCH
Pete will wAtsapp you mate sure I have some pictures of adaptors etc for spa gauges
31 Re: Spa gauges on 22nd November 2015, 8:21 am
Cheers Johnny, might sound a daft question but what's the actual point in knowing your in out temps on your cooler.....
32 Re: Spa gauges on 22nd November 2015, 9:29 am
It's just a good idea to know what temp the air is as its leaving the cooler and heading for your engine. I think the warmer the air is, increases the chance of det plus warmer air reduces power. Im wanting an in/out setup as I'm planning on experimenting with top mounts.
33 Re: Spa gauges on 22nd November 2015, 9:10 pm
I put mine on when I fitted intercooler sprayer to see it drop
