Gtir Motorsport club » Tech room » Help and Advice » Heater unit
Heater unit
1 Heater unit on 24th November 2015, 7:53 pm
Hi Lads
My heater unit stopped working before the clutch gave up it was either on or off no intermediate settings
I thought I saw a topic on here from bob??? on how to open up the unit and fix the unit by soldering or hitting with a hammer LOL
Any Ideas, if not can they be fixed or is mine doomed to the scrap pile?
cheers Tom
ps mine is the push button type with knob on the right hand side off an L reg R
2 Re: Heater unit on 24th November 2015, 7:56 pm
I have the same problem with mine, im just gonna get a replacement of bob at some point
3 Re: Heater unit on 24th November 2015, 8:16 pm
I did abit of a search I can't find anything about soldering
4 Re: Heater unit on 24th November 2015, 8:24 pm
Gtirchris
It might just be the resistor card as that is the usual culprit, it's located on the bottom of the heater box, held in place with a couple of screws, try testing it with a multimeter to see what voltages you are getting for each fan speed.
5 Re: Heater unit on 24th November 2015, 9:08 pm
Thanks Chris found it!!
Ive just swapped over the card from my old sunny which is identical looking, so hopefully in a couple of weeks when the engine is up and running the heater should work on all 4 settings
many thanks Smile
6 Re: Heater unit on 25th November 2015, 7:47 pm
Gtirchris
No worries mate, hopefully it'll work OK.
7 Re: Heater unit on 26th November 2015, 9:35 pm
Yes as Chris has said it will be just the heater card needs replacing 99% of the time
                                GTI-R-US.CO.UK
                                            'In association with'
                                          'Services provided'
