Gtir Motorsport club » Tech room » Help and Advice » My Oil pump teardown - Caught just in time
1 My Oil pump teardown - Caught just in time on 30th November 2015, 10:02 pm
Can anyone help me decide if I can get away with buying just the internal gyrators or do I need a whole new pump assembly?  anyone?
This is the outer gyrator, heavily pitted and covered in bits of the bearings; Surprised
The inner gyrator is cracked right thro!!! and also covered in bearing shit,  Shocked
But are these housing salvageable???  Neutral  Neutral  Neutral
2 Re: My Oil pump teardown - Caught just in time on 30th November 2015, 10:14 pm
Replace the whole lot, thats what i would do
3 Re: My Oil pump teardown - Caught just in time on 30th November 2015, 10:16 pm
get complete pump housing, they cheap in US, if include set of pistons & barter a bit it will be cheap for all new quality parts.
4 Re: My Oil pump teardown - Caught just in time on 30th November 2015, 10:20 pm
@pulsarmoley wrote:Replace the whole lot, thats what i would do
yeah, its bit obvious this one,
Wish i never posted this, i feel like a tit now.
Ill look for a delete button.
Embarassed
5 Re: My Oil pump teardown - Caught just in time on 30th November 2015, 10:21 pm
^ never need to worry about posting here mate, doesn't matter Smile
6 Re: My Oil pump teardown - Caught just in time on 30th November 2015, 10:23 pm
Embarassed
Always worth double checking if your not 100% though, money saved in one area can be spent in another Wink
7 Re: My Oil pump teardown - Caught just in time on 30th November 2015, 10:30 pm
@Mr B wrote:get complete pump housing, they cheap in US, if include set of pistons & barter a bit it will be cheap for all new quality parts.
Ive created a parts list for Erics Performance and its at $1200 so far,
Im just waiting to see if i can get used pistons, if not ill add them to the order and see what discount he can do... Very Happy
8 Re: My Oil pump teardown - Caught just in time on 30th November 2015, 10:44 pm
ouch :-S
I would price frsport against erics.
Also see if anyone else wants small bits that you could resell with minor markup but still cheaper than them buying one 10buck item & shipping, things like gear linkage poly bush is wanted a lot, they about $6 from frsport & about $20 on ebay, just a thought, used pistons unless super cheap never work out good by time check um out & buy new rings.
9 Re: My Oil pump teardown - Caught just in time on 1st December 2015, 6:25 am
Embarassed
Not to worry, the only tit would be the person lambasting you for at least asking the question for help.
Ask away with your questions, only way to learn and also get good advice, as has been given.
10 Re: My Oil pump teardown - Caught just in time on 1st December 2015, 11:59 am
Embarassed
cheers dude, feel a bit better now
Smile
11 Re: My Oil pump teardown - Caught just in time on 1st December 2015, 12:12 pm
@Mr B wrote:ouch :-S
thats a good point, thanks,  thumbsup
i've had a call from the engineers and Johns bores are 0.127 over-worn so ill be getting them rebored to 86.5mm.
they need the pistons first tho, as they bore to suit.
you make a good point Re pistons i'll buy them new,
I'll also raise a post and ask if anyone wants to order share.
Smile  Smile  Smile  Smile
12 Re: My Oil pump teardown - Caught just in time on 1st December 2015, 1:52 pm
^ sign of a good engineers asking for the pistons first (taken from Mr B's bible)
13 Re: My Oil pump teardown - Caught just in time on 1st December 2015, 4:58 pm
^ yes it a good sign, don't machine anything till got parts and clearance specs etc checked/confirmed . Other thing is if have shells & pistons in hand they got no excuse really if did mess it up ;-/
14 Re: My Oil pump teardown - Caught just in time on 1st December 2015, 5:09 pm
@Mr B wrote:^ yes it a good sign, don't machine anything till got parts and clearance specs etc checked/confirmed . Other thing is if have shells & pistons in hand they got no excuse really if did mess it up ;-/
That's my thoughts too. Block, head and crank all tested/machined in one place, all other parts are new parts, so no excuse if my oil pressure is rock bottom due to excessive clearance etc.
Plus i'm getting the crank, fwheel, clutch and pulley balanced as an assembly so i expect supersmooth results..Very Happy
A few years ago they did an XR3i rebuild and seemed to do a good job of that, plus they're very busy which is a good sign.
Smile
15 Re: My Oil pump teardown - Caught just in time on 1st December 2015, 7:50 pm
Was that oil pump out of my old engine?? Embarassed
16 Re: My Oil pump teardown - Caught just in time on 1st December 2015, 8:26 pm
Hey John,
Hope you're well?  Smile  Smile  Smile
No that was out of my old engine which had spun its bearings.
I also tried to open your's up but the bolts were torqued up to 900000000000Nm and bent my spanner Shocked
Kind of Gods way of telling me to buy a new one i think Cool
17 Re: My Oil pump teardown - Caught just in time on 1st December 2015, 8:36 pm
Seigen brand of walldrive spanners not bad for money
see tool thread > http://www.gtir-motorsport-club.com/t5665-cheap-but-surprisingly-good-spanners
18 Re: My Oil pump teardown - Caught just in time on 1st December 2015, 8:53 pm
@Mr B wrote:Seigen brand of walldrive spanners not bad for money
I also need a 12mm moon spanner to undo 1 propshaft bolt,
Bought a set from machine mart yesterday, got home and found none were 12mm!
There was a 10/11, 13/14 etc
I mean who f&*k needs 11mm instead of a 12mm??
really sad
19 Re: My Oil pump teardown - Caught just in time on 1st December 2015, 8:59 pm
Americans lol .
20 Re: My Oil pump teardown - Caught just in time on 1st December 2015, 9:03 pm
will the s-spanner do > http://www.ebay.co.uk/itm/Siegen-S-Spanner-Set-5pc-Metric-S0717-/391256699257?hash=item5b18b77179
take um back & get machinemart swap um for set with 12mm > https://www.machinemart.co.uk/p/040212493/
21 Re: My Oil pump teardown - Caught just in time on 1st December 2015, 9:08 pm
@Mr B wrote:will the s-spanner do > http://www.ebay.co.uk/itm/Siegen-S-Spanner-Set-5pc-Metric-S0717-/391256699257?hash=item5b18b77179
Them'll do, but i ordered a used one from fleabay for £4, should come 2mrw.
Very Happy
22 Re: My Oil pump teardown - Caught just in time on 1st December 2015, 10:34 pm
Spark plug spike
I also need a 12mm moon spanner to undo 1 propshaft bolt:
Just jack the back of the car up using the rear diff so the rear wheels are off the floor, release handbrake if on, then rotate the rear wheels until the prop shaft bolt is accessible at the bottom then lower the car back down and remove with normal 12mm spanner cheers
Hope that makes sense I've always done it this way to disconnect the prop shaft?
23 Re: My Oil pump teardown - Caught just in time on 1st December 2015, 10:43 pm
I didnt think if that, cheers ill give it a go 2mrw, should only take 5 mins,
By the way, does the propshaft and tranny output flange have to be marked so they're re-assembled back the same way?
Smile Smile
24 Re: My Oil pump teardown - Caught just in time on 1st December 2015, 10:45 pm
Just tipex both sides before you take it off .... i didnt mine and it went back all ok ...
