Gtir Motorsport club » active members adverts » Parts Wanted » Warm air duct pipe
Warm air duct pipe
1 Warm air duct pipe on 6th December 2015, 5:03 pm
I'm after what I assume is a plastic air duct that runs in the passenger footwell behind the glove box, all I have is a hole on the left with a fan in it and a hole opposite on the right, it blows cold air so I'm assuming it pushes air through the heat exchanger and out the vents, it's about 12 inch long I recon.
2 Re: Warm air duct pipe on 6th December 2015, 10:55 pm
@Bones wrote:I'm after what I assume is a plastic air duct that runs in the passenger footwell behind the glove box, all I have is a hole on the left with a fan in it and a hole opposite on the right, it blows cold air so I'm assuming it pushes air through the heat exchanger and out the vents, it's about 12 inch long I recon.
Sounds like you need #7 and #12 http://nissan4u.com/parts/sunny/er_n14/1990_11/type_23/body_electrical/nozzle_and_duct/illustration_1/
3 Re: Warm air duct pipe on 7th December 2015, 8:47 am
Ill see if ive got any left for you bones
4 Re: Warm air duct pipe on 8th December 2015, 6:51 pm
Think I only need 12 but I'll check . Thanks Beeb
5 Re: Warm air duct pipe on 14th December 2015, 7:27 pm
Any news on this Beeb
6 Re: Warm air duct pipe on 14th December 2015, 8:30 pm
ah sorry no haven't got that one im afraid
7 Re: Warm air duct pipe on 19th March 2016, 8:25 am
Can anyone else help with this pipe?
8 Re: Warm air duct pipe on 19th March 2016, 10:04 am
Yes I'm sure I have those pipes.
#7 & #12 ???
9 Re: Warm air duct pipe on 19th March 2016, 10:18 am
10 Re: Warm air duct pipe on 19th March 2016, 10:35 am
@Stu wrote:
These pipes go to the back of the air vents in the dash.
Is that what you need?
Both or just the one side?
11 Re: Warm air duct pipe on 20th March 2016, 3:07 pm
I need the passenger side pipe, it's just above your toes when your sat in the seat. Goes from left were wheel arch is to right were ecu is kept. Not the ones that go up to the air vents. Basically it blows cold air on our lasses feet and when I put my hand in the footwell you can feel cold air being blown out of a pipe just behind the abs brain. I put my fingers inside the pipe only to get them whacked by some sort of high speed fan
12 Re: Warm air duct pipe on 20th March 2016, 6:23 pm
To my knowledge there isn't a pipe that goes from wheel arch to ecu!
The motor and its couling is on the left of the footwel. Then that attaches to the aircon radiator couling and then that Conects to the matrix.
Then you have those two pipes I have shown that go from each side of the setup to the air vents on the dash.
13 Re: Warm air duct pipe on 20th March 2016, 8:27 pm
I'll have to get under and take some pictures mate
14 Re: Warm air duct pipe on 21st March 2016, 5:48 pm
This is the fan to the upper left of the passage footwell that it blows cold air from
15 Re: Warm air duct pipe on 21st March 2016, 6:38 pm
Looks like you need the casing that holds the aircon radiator. .
16 Re: Warm air duct pipe on 21st March 2016, 6:59 pm
Ah I see, the air on was removed before I got the car so I don't know what's ment to go there, is it something you have Stu as if I need to ask lol
17 Re: Warm air duct pipe on 21st March 2016, 7:08 pm
