Gtir Motorsport club » Tech room » Help and Advice » Where does this go? Do i need it if i'm rebuilding my engine?
http://www.importcarparts.co.uk/parts-info?id=10310&cat=87&sub=119&sec=0&var=0&dc=&gen=&searchKey=&searchPart=
Smile
Spigot bearings usually go in the end of your crank where it mates up to your gearbox shaft. And just depends on the condiditon of your old one but wouldnt hurt for that sort of money.
Is it inside the crankshaft near the flywheel end? I don't recall seeing this when i stripped my engine recently  Shocked
Yep you've got it, they're inside the crank at the flywheel end that the input shaft of the gearbox locates into, it would be a light press fit in there so may well still be in the crank?
edited, will post later
gtir does not run a spigot bearing which is probably reason why so many have noisy input shaft bearings
