Gtir Motorsport club » General Discusion » Gtir related Discussion » Another gearbox.....
Go down  Message [Page 4 of 5]
76 Re: Another gearbox..... on 3rd January 2016, 2:07 am
As said I have the straight cut ppg dog box in my Rasheen and can change gear fine with it but you are much more likely to chip 1st and 2nd gear if using Car on road.
The dog engagement is designed to be banged into gear and ideally flat shifted which is impossible on a road car. If you pussy foot around trying to select gear without crunching it then you are much more likely to do just that and cause damage to the gear.
Also the gearing is a higher ratio than standard gearset so ideally you need the 5th even if it's just to rest your ears on a motorway from the constant whine of the straight cut gearing.
So it depends what car is mainly used for but tbh I think a straight cut synchro is always going to be the best option unless it's purely used as a full on track car
That's my opinion anyway
77 Re: Another gearbox..... on 3rd January 2016, 10:38 am
I've just been reading pars offerings. They do the needle roller bearing conversion and was wondering can this be used on standard gearsets or only pars gearsets
78 Re: Another gearbox..... on 3rd January 2016, 10:48 am
I've thought about it over night and synchro is the way forward for me, for how much time it would be on the roads etc compared to track I just can't justify a dog box for my needs
79 Re: Another gearbox..... on 4th January 2016, 10:55 pm
Are you thinkong of going pig pete.?
80 Re: Another gearbox..... on 4th January 2016, 10:56 pm
Sorry ppg
81 Re: Another gearbox..... on 15th January 2016, 6:04 pm
No par Darren, ordered my set, just hope I don't have any problems, seen a link but it was from 2005 about a guy who's par set bust through the bell housing twice, but also heard a lot of good things!!
82 Re: Another gearbox..... on 15th January 2016, 6:08 pm
You ordered it ?
83 Re: Another gearbox..... on 15th January 2016, 6:15 pm
Yes....
84 Re: Another gearbox..... on 15th January 2016, 6:18 pm
How much and what exactully did you order mate
85 Re: Another gearbox..... on 15th January 2016, 6:23 pm
1st to 4th straight cut set, it works out at £2150, then there will be import tax on top, buying a stratcher gear box brace as well
86 Re: Another gearbox..... on 15th January 2016, 6:24 pm
I wanted to keep oem 5th
87 Re: Another gearbox..... on 15th January 2016, 6:32 pm
Nice one get it spent mate. Did you find anything on uprated selector forks
88 Re: Another gearbox..... on 15th January 2016, 7:58 pm
Not what I wanted this time of year but I'm fed up of taking the bloody box out every other week, I've not made my mind up yet about the selector tbh, not 100% if it's totally needed, part of me thinks I'll probably be fine without it (as I've never had a problem) and could save a decent wedge, and the other thinks just do it whilst it's apart, but then with what bob said about them I think I'll leave it.....
89 Re: Another gearbox..... on 15th January 2016, 9:42 pm
@PartyPete wrote:I wanted to keep oem 5th
Good for cruising around without the whine. I have oem 5th aswell.
90 Re: Another gearbox..... on 15th January 2016, 9:53 pm
Will this mean I wont have anyone to pick on soon Sad Sad
91 Re: Another gearbox..... on 15th January 2016, 9:56 pm
ckd281081
"No par Darren, ordered my set, just hope I don't have any problems, seen a link but it was from 2005 about a guy who's par set bust through the bell housing twice, but also heard a lot of good things!!"
Thats because he would have still had a standard final drive, and probably 5th gear, causing the same side axial load that bursts the gearbox housings. I ordered from PAR also but went for the full whack including final drive and billet selector. They are brilliant to deal with and good value for money. Import tax is indeed shit though....
92 Re: Another gearbox..... on 15th January 2016, 10:53 pm
@shroom wrote:Will this mean I wont have anyone to pick on soon Sad Sad
I hope not!! But I'm sure you will figure something new out to entertain us Razz
93 Re: Another gearbox..... on 15th January 2016, 10:54 pm
@ckd281081 wrote:"No par Darren, ordered my set, just hope I don't have any problems, seen a link but it was from 2005 about a guy who's par set bust through the bell housing twice, but also heard a lot of good things!!"
I'll just have to wait and see, how much import tax you paying?
94 Re: Another gearbox..... on 15th January 2016, 11:53 pm
@PartyPete wrote:No par Darren, ordered my set, just hope I don't have any problems, seen a link but it was from 2005 about a guy who's par set bust through the bell housing twice, but also heard a lot of good things!!
That was probably an Aussie guy from Queensland. There was a problem with the machining that caused the breaks but once PAR figured it out and modified the machining it fixed the problem. So they should be all good now.
95 Re: Another gearbox..... on 16th January 2016, 4:15 am
current PAR designed kit is very good for the money, gone full straightcut now while early syncro kit was semi helical I believe . Most chance of case issues is 1st 2nd & 3rd, quite easy double end strength of case nose with resin mould & steel plate, I use steel as can use thinner material keeping maximum working space in a already tight area. for serious hp & drag use then strengthening plate can be added to bell housing base but best effort requires moving to custom hydraulic release so you get space to make most of plating effort. welding got to be top notch or it will actually be more weak.
PAR mixed with sensible case work = a box that can take a good 500hp & some rough use at sensible budget.
If serious big power & competitive drag use then transmission issues are likely what ever you do.
the trust gearkit made for them by quaife looked a seriously decent bit of kit, bit rare though.
96 Re: Another gearbox..... on 16th January 2016, 8:47 am
I was hoping it was an old manufacturing issue, I am talking 11 years ago!
97 Re: Another gearbox..... on 16th January 2016, 8:51 am
@Mr B wrote:current PAR designed kit is very good for the money, gone full straightcut now while early syncro kit was semi helical I believe . Most chance of case issues is 1st 2nd & 3rd, quite easy double end strength of case nose with resin mould & steel plate, I use steel as can use thinner material keeping maximum working space in a already tight area. for serious hp & drag use then strengthening plate can be added to bell housing base but best effort requires moving to custom hydraulic release so  you get space to make most of plating effort. welding got to be top notch or it will actually be more weak.
I know you can buy the strengthening plates for the bell housing that weld in place, but I think I would have to change my clutch,,and at the power I'm running I can't see it being that necessary....
98 Re: Another gearbox..... on 21st January 2016, 7:30 pm
My gearset turned up today,not bad saying I ordered them Sunday, must say they look sturdy! Looking forwards to fitting them and taking them for a drive
99 Re: Another gearbox..... on 21st January 2016, 7:40 pm
Didnt take them long to get them to you. Must've been on the shelf with your name already on them.
Rumour has it that everyone in the gearbox world has heard of your miss fortune with gearboxes lol
Think you're known as Gearbox pete or is it broken box pete. .
Something like that haha
100 Re: Another gearbox..... on 21st January 2016, 7:41 pm
Get me pictures gearbox porn is a must for me
Back to top  Message [Page 4 of 5]
