Gtir Motorsport club » Tech room » Help and Advice » Power steering setup with cooler
1 Power steering setup with cooler on 22nd December 2015, 5:51 am
Does anyone of some good pictures of the power-steering setup?
Thinking about putting standard power steering back on my car but looking at what I need. All I have at the moment is the power steering pump and bracket.
Considering I don't have all the other crap I was thinking of using braided hose and a custom reservoir.
From memory the power steering lines loop in front of the radiator? Whats the real purpose of this? cooling? pressure?
2 Re: Power steering setup with cooler on 22nd December 2015, 6:05 am
I'm also interested to know why the diameter of this line running off the power steering pump is considerably larger than the hard line it connects to? Could I run braided line straight from the pump that is the same diameter as the hard line?
thanks for the pic stu Laughing
3 Re: Power steering setup with cooler on 22nd December 2015, 2:09 pm
Laughing you're welcome Smile
I do believe the pipe that sits in front of the radiator is for cooling but it may just be because there wasn't anywhere else to put it?
I have no idea if you could just use braided lines but at a guess I wouldnt have thought the standard hoses were anything special?
Would have thought there's an empty engine bay picture somewhere that will give you an idea of how it's all installed?
4 Re: Power steering setup with cooler on 22nd December 2015, 3:45 pm
The loop is indeed a basic cooling function.
You could use some qaulity braided line & crimped fittings but expect you could pull a few of the pipes & reservoir from a breakers yard.
5 Re: Power steering setup with cooler on 22nd December 2015, 5:10 pm
I don't have the steel loop on and it's been fine so far
But it is cold out
6 Re: Power steering setup with cooler on 22nd December 2015, 5:57 pm
None of the power steering pipes, rubber and hard (left myself open to shroom jokes) are available anymore, checked a few weeks back as all the rubber ones are goosed on mine.
7 Re: Power steering setup with cooler on 22nd December 2015, 6:13 pm
My rubbers are also fooked so ill be on the look out for braided or might even go hyraulic crimped pipes.
8 Re: Power steering setup with cooler on 22nd December 2015, 8:17 pm
Thanks guys. As I don't have the hard lines either, I was thinking braided hose all the way. By sounds of it ill need to consider cooling. I probably shouldn't run the hose straight from the pump to the reservoir and back again.
9 Re: Power steering setup with cooler on 22nd December 2015, 8:20 pm
@mc_hawkings24 wrote:I don't have the steel loop on and it's been fine so far
But it is cold out
Where is yours looped? Now I remember on my old 4door pulsar I removed the steel loop and used abit of hose to loop the 2 hard-lines near the head-lights somewhere I think.
10 Re: Power steering setup with cooler on 22nd December 2015, 8:43 pm
If you want a cooler then im sure something from another could be made to fit?
11 Re: Power steering setup with cooler on 22nd December 2015, 8:44 pm
Thats what I was thinking mate, just a small cooler, there is plenty of room for one.
12 Re: Power steering setup with cooler on 22nd December 2015, 8:52 pm
Some people were using cooler off a scooter once similar to a small version of a x row oil cooler
13 Re: Power steering setup with cooler on 22nd December 2015, 9:27 pm
Thanks Johnny Ill look into that. As my fans are mounted on the front of the radiator may need to look at another location for one then.
14 Re: Power steering setup with cooler on 22nd December 2015, 10:18 pm
For what it is what about behind wheel in arch or nice custom one behind grill. The cheaper rads on e bay build the pipes in and it flows along the  tank
15 Re: Power steering setup with cooler on 22nd December 2015, 10:56 pm
Good plan mate, Ill see what sizes are available and wheres the best mounting place is.
What should I looking for? The descriptions vary but there are 2 types from what I can see. I would have thought the first is more used for engine cooling.
16 Re: Power steering setup with cooler on 23rd December 2015, 12:22 am
one similar to second image would be fine.
17 Re: Power steering setup with cooler on 23rd December 2015, 12:40 am
Woody, these are the diags for the PS
Pump and PRESSURE lines
http://nissan4u.com/parts/sunny/er_n14/1990_11/type_23/axle_suspension_and_steering/power_steering_pump_power_steering_pump_mounting_and_power_steering_piping/illustration_1/
Brakets and housing
http://nissan4u.com/parts/sunny/er_n14/1990_11/type_23/axle_suspension_and_steering/power_steering_pump_power_steering_pump_mounting_and_power_steering_piping/illustration_3/
Reservoir and front cooling piping
http://nissan4u.com/parts/sunny/er_n14/1990_11/type_23/axle_suspension_and_steering/power_steering_pump_power_steering_pump_mounting_and_power_steering_piping/illustration_4/
Diagram 1
#3 is the reservoir.
#19 is the rubber hose line from the reservoir to the pump.
#23 is the PRESSURE line (important – it is pressure) and the flexible connector from the pump to the solid lines. This connects to the steel line (#4) with the banjo bolt (behind the tower) and the steel line runs down and attaches to the steering rack.
#31 is the return line from the steering rack. This line goes to the front cooler line.
Diagram 4
The #31 return line (diag 1) attaches to the cooler line at (a), runs through the cooler and returns to the reservoir and is attached at hose #2.
hth
18 Re: Power steering setup with cooler on 23rd December 2015, 1:14 am
Thats great mate, I looked at those diagrams but your explanation really helped Smile Pretty much have an idea now Smile Need to look at fittings and hose now.
19 Re: Power steering setup with cooler on 23rd December 2015, 9:14 am
Late arrival but i looped it back like you did in your 4dr woody
20 Re: Power steering setup with cooler on 23rd December 2015, 6:38 pm
http://www.thenismoshop.com/STILLEN-Power-Steering-Cooler-Kit-400736--Nissan-370z-Infiniti-G37_p_149.html
21 Re: Power steering setup with cooler on 23rd December 2015, 6:40 pm
https://s1085.photobucket.com/user/ruezmag/media/20131031_084227_zps474a6dae.jpg.html
These heat sink ones look nice both these and the other ones come
Rectangle or square etc
22 Re: Power steering setup with cooler on 23rd December 2015, 7:44 pm
The one in the second link looks pretty easy to mount Johnny.
23 Re: Power steering setup with cooler on 23rd December 2015, 7:54 pm
Few options yes looks yes it dose  and l like it as so much smarter than the rusty looking original pipe
24 Re: Power steering setup with cooler on 23rd December 2015, 7:56 pm
http://www.amazon.com/NCY-0900-1026-Ruckus-Oil-Cooler/dp/B00CMU9G5G
But this one or similar would require more protection than the above tube type
25 Re: Power steering setup with cooler on 23rd December 2015, 8:57 pm
Something like this could might also work. Its only small but would mount easy into the side of wheel arch etc.
