Gtir Motorsport club » Tech room » Help and Advice » Power steering setup with cooler
26Power steering setup with cooler - Page 2 Empty Re: Power steering setup with cooler on 24th December 2015, 5:38 pm
@gtir_woody wrote:Something like this could might also work. Its only small but would mount easy into the side of wheel arch etc.
Power steering setup with cooler - Page 2 Image
That one imo would be better, i thought the other two were a bit overkill?
27Power steering setup with cooler - Page 2 Empty Re: Power steering setup with cooler on 24th December 2015, 7:49 pm
I think a small cooler would be fine.
28Power steering setup with cooler - Page 2 Empty Re: Power steering setup with cooler on 30th December 2015, 7:33 am
Im going to mount the cooler between the return from the power steering rack and the reservoir, could anyone confirm this is correct? Smile
29Power steering setup with cooler - Page 2 Empty Re: Power steering setup with cooler on 30th December 2015, 8:13 am
As you can see on this diagram (copied from above), the return line is the one that connects at the point (a), runs forward through the steel loop cooler across the front of the radiator and returns to the reservoir.
So yes, between the return line and the intake point of the reservoir.
http://nissan4u.com/parts/sunny/er_n14/1990_11/type_23/axle_suspension_and_steering/power_steering_pump_power_steering_pump_mounting_and_power_steering_piping/illustration_4/
30Power steering setup with cooler - Page 2 Empty Re: Power steering setup with cooler on 30th December 2015, 8:28 am
thank you sir Smile
31Power steering setup with cooler - Page 2 Empty Re: Power steering setup with cooler on 24th January 2016, 8:23 am
So I ended up getting the small cooler I was talking about on the previous page. its a rather nice fit behind the front grill Smile
Power steering setup with cooler - Page 2 Full_Size_Render_123213
32Power steering setup with cooler - Page 2 Empty Re: Power steering setup with cooler on 10th August 2017, 8:18 am
for the sake of updating this thread with the end result, I mounted the cooler in the wheel arch.
Power steering setup with cooler - Page 2 IMG_3515
33Power steering setup with cooler - Page 2 Empty Re: Power steering setup with cooler on 10th August 2017, 6:21 pm
Why instead of grill mate
34Power steering setup with cooler - Page 2 Empty Re: Power steering setup with cooler on 10th August 2017, 7:52 pm
The lines were really tight around the radiator mate
35Power steering setup with cooler - Page 2 Empty Re: Power steering setup with cooler on 11th August 2017, 10:18 am
astarozna
astarozna
I see you are not running rubber bushes, if it's alloy rad then you are more then likely to crack it.
36Power steering setup with cooler - Page 2 Empty Re: Power steering setup with cooler on 12th August 2017, 8:02 am
Probably should, see heaps of people have them like that though.
